One last warning about using oscillation in this coil.
https://www.youtube.com/watch?v=It1rLHM9gOw Halfway through this video is the exact reason I am so worried. At around the 5 minute mark he exclaims "oooh". Then apologizes about the video quality because of a Dizzy spell after the unit starts.. This is because of emf sickness from the field going in and out from the tube. You will have that same experience at some point. This is when you need to stop. This design was not made for AC currents Since it magnifies the field and then releases it with addition force from the waffling signal. Please use at the least a dc pulse, I beg you.. Make sure the pulse does not go below the zero volt line. This is very important.
Does anyone remember the Cap discharge experiments that shrunk coins? Imagine that happening in mater all around this coil.
My opinion is that this device uses a pressure of energy(Impulses) in one direction. It is not designed for oscillation but a stream.
Much like how they harvest energy from Niagara falls.
I see this 007 design operating like the bicycle tube as an example of the plasma that forms. It compresses it through the successive overlapping rings of conductors. It also twists the plasma in the same action. Each successive squeeze packs more plasma inside of the coils in a torus and lets it rebound assisted into the reflector shorted coils. When the energy is highest it will discharge beyond the reflectors ability to maintain the reflective inductive characteristic of the wire. This swill send huge blasts of magnetic field out from the coils in the shape of the spaces between your wire loops. Technically you would be doing the same process as a laser at that point. Who knows what frequencies it would include. As you have seen there are 3 signals on the test scope... The proof is there you only have to be willing to recognize what it is and how it is operating.
I am also of the opinion that 007 knew this. It is a way of discrediting Marko's design through how dangerous it would be to utilize it this way. Didn't the breaker pop as well during 007's presentation. That was most likely due to the amount of current he was generating through the blasts hitting the charged wires in that area. Kinda like an EMP... But it doesn't mean the design is faulty. Just that you are not using the right source to drive it. This stuff acts like it is dc but it isn't. it has the finest division of the plasma matter individually exciting matter and conveying a potential change only. As a response plasma flows into the mater. The flow is dictated by the plasma density with higher densities conveying energy through all mater with increased density. Mater will puff slightly but it will be able to amplify it's energy permissive nature and amplify the results.Plus being in this field amplifies your own energy. This was the magnifying effect Tesla discovered. You impulse the density and tune receivers to that impulse train frequency and they tap that energy. To boot it also amplifies it allowing more work to be done passing energy to and from the matter. Like i said the mater will puff slightly but tight control over this is simple to install harmonic dampeners. Or better yet power source outlets for traditional AC on the spot converters, till we get our tools and daily life stuff converted over. Once we learn how to circulate larger portion of space we can set up mini environments with all the trappings of home including central gravity weather like wind and rain if needed. Why do you think Tesla anchored the tower so deep for. It wasn't a ground plane. It was an anchor to keep the tower from rising from all the plasma density in a sphere all around the tower. That included the ground to. Remember plasma density is dictated by buoyancy rules. Raise the density of the plasma and Walla a plasma balloon. I think I don't need to say Coral castle do I?.. Leedskalnin used water to penetrate the coral and excited the water to unleash the plasma within it. This floated the coral like a balloon. This energy is friendly to the human condition and others have shown it, by using lighting in water and reaching in while it is running where it does nothing to them.
This sounds fantastical but this is what Tesla envisioned for us. Plus you can be as safe as you please in these spheres Nothing can penetrate the shell if you don't want ti to that includes space itself. Tesla taught us lighting techniques as well to use with this kind of system. Tesla didn't go into the energy system because he had difficulty doing such after Wardencliff. But he did continue and designed a system that was portable due to a virtual ground system. A system that connects to the ground inductively through the plasma system already flowing around us going twords the vacuum of plasma in the center of our core that is displaced by condensed mater or bound plasmoids. Remember plasma is the fourth state of matter. And all matter is condensed mater. Learn how to change the density of condensed matter and you increase it's energy capability. The very same thing happens when you cool a wire down to it lowest levels. What happens? Resistance lowers. All radiant heat is how much charge is running through space. More plasma then higher heat levels will be felt or to be exact the capability to transfer heat is augmented in that space.
The easiest way to do this would be to make the Earth one electrode and cause the plasma to condense around the whole planet further. Everyone and everything would be augmented and so would our current technology. The one problem i can see is that we would have to lower our AC sources down to a very low level around the whole planet to adjust for the increased conduction around the globe. More testing should prove this out very easily. We can even block anything from enering our atmosphere by using the tremendous energy on that atmosphere surface. This includes invaders from space ROFL! Tin foil hat applied...
:P This is actually my last post don't worry.. Someone is helping atm that can see this as well. Please don't hurt yourselves with this version of the Rodin coil and using AC or RF currents.
