« Reply #375, on July 14th, 2016, 10:26 AM »Last edited on July 14th, 2016, 10:28 AM
cool PJ,
yes please post the screen shot, would live to see them!
27mm is a small hole! But it can be done!
we must test everything :)
PJ
« Reply #376, on July 14th, 2016, 12:55 PM »
I think i have a better idea :)
The second stage phi torus is based on phi^3 : 1 for outer diameter to inner diameter and a grid of 36 x 36.  12 circuits all looping through the torus once.
Phi^3 = 4.2358...
The 36 in the 36 x 36 grid is made from four 9 x 9 number grids therefore the 36 x 36 grid can also be considered as a 4 x 4 grid (where each magor grid is made up of a minor grid of 9 x 9).
In summary torus proportions are:
4.2385:1 for 4 x 4 grid.
Ok the third stage phi torus is based on phi^5 : 1 for outer diameter to inner diameter and a grid of 36 x 99. 3 circuits each looping through the centre 4 times.
Phi^5=11.089...
The 36 x 99 grid when broken down to 9 x 9 sub grids gives a 4 x 11 grid.
11.089:1 for 4 x 11 grid.
Do you see the pattern....? :P
Approx. 4:1 proportions for 4 x 4 grid and approximately 11:1 proportions for 4 x 11 grid!
Ok the first 4 in the 4 x 4 and 4 x 11 grids is always 4 so if we consider the second numbers I'm pretty sure that even second numbers result in many circuits (possibly always 12?) looping through the centre once and odd second numbers result in less circuits (possibly always 3?) looping through the centre 4 times.....
So my thought is this - why not move one grid up from the 4 x 4 grid to 4 x 5 which should have proportions approximately 5:1 and 3 circuits each looping through the centre 4 times??
Definitely buildable and following closely to the phi proportions.
What do you think?
PJ
PJ
« Reply #377, on July 15th, 2016, 04:22 AM »Last edited on July 15th, 2016, 04:27 AM
Ok I have done some work on the 4x5 (36x45) torus design.
I have attatched screen captures, notes and a 3DS Max file.
I'm hopping some one in the group will have better skills, more time and the enthusiasm to take this further and model the formers :)
Cheers
PJ
talisman
« Reply #379, on July 16th, 2016, 08:02 AM »
Marko said the coil is ready. Should he have supplied a coil? I will have to assume the original design is validated now that we are adding hubcaps and spokes to the wheel with each needing their own separate validation.
« Reply #380, on July 17th, 2016, 10:02 PM »
Anyone got anything new to share? Seems me time to work on this project is slim. Trying to get some more work and a video maid on what I did so far.
In the mean time. Here is a new C clip that Jim and I have created.
Will load the STL file Tomarrow. Basicaly it's a rotatable clip so the wires stay in place.
We have been testing the new 36 slot Phi toruis. It seems the small hole is to small. The wire dose not fit. To steep of an angle.
We may need to use the same hole size and make the outter bigger to match the Phi ratio.
More to do.
Also to answer talisman question.
Markos "coil" would be directly the math. That's what the new Phi frame will be.
The 007 coil still stands as * needs to be verified.
And I'm still going forth with that.
PJ
« Reply #382, on July 18th, 2016, 12:01 AM »
Hi Russ
You show a 3D image of where the windings are too tight for the latest torus you are designing.
Could you post a 3D image of the completed new torus you want including windings, torus dimension, thickness you want for formers etc.
I'll assume you want 4mm wires.
I think I may br able to model something that will work for you
PJ
« Reply #385, on July 18th, 2016, 09:33 AM »
This is without a doubt a very hard project.
The efforts shown by people on this Web site is truly amazing - particularly your efforts Russ.
I for one hope you are able to keep going with this project.
Don't worry about posting a 3D file for me - i have looked at your photos and last 3D image and I can see each former has 36 wire spaces and that there are 11 formers so i should be able to model the path.
Ill assume you want 270mm outer diameter with phi : 1 proportions for the inner diameter.
Its 2:30am here - I've just fed our baby and im awake so I'll have a crack at a former that might work for you - it may not have the lightening holes and connection cutouts yet but ill send you a .stl so you can let me know if you think this may work.
PJ
PJ
« Reply #388, on July 18th, 2016, 10:56 AM »Last edited on July 18th, 2016, 10:59 AM
Ok I have created a 3D model that matches as far as I can tell Russ's latest design.
I think this will work.
I will attatch 2 screen captures, 2 .stl files and the .max file showing what I have done and where I am up to.
Further work needs to be done to create the lightening holes and connections etc.
Dimensions are 270mm outer diameter, 63.74mm inner diameter (to centre of wires), and 3mm thick formers.
Two wires have been allowed for as per the math - do you want the extra wire space?
Let me know if you want any other changes.
PJ
« Reply #389, on July 18th, 2016, 11:08 AM »
PJ, i haven't uploaded the new files due to them not working... we are still working on it. however i will upload them so you can try to lay a wire path...
but you can see it wont work.
Jim is currently working on the new 90mm inside former and ring.
current files that are in good working order but should not be used due to wire path constraints attached...
« Reply #390, on July 18th, 2016, 11:12 AM »
PJ good idea using the wire path as the slot maker... so to do a 36x36 with the smaller hole the wire should go through the hole 2 times, a total of 4 coils doe " A,B" and then the gap space...
you currently only have a single turn in the hole. make sense? doing it like you are will be good to see if its possible to do a real 36x36 ( even tho we are using 11 former's... )
« Reply #391, on July 18th, 2016, 11:21 AM »
Quote from Gunther Rattay on July 18th, 2016, 08:53 AM
It would have been much easier to start with Marco´s coil, get proof of concept and then make modifications.
Marko dose not " have a coil"  the 007 coil is just a modification of Danial's. however 007 uses only one turns. this is what Marko states is correct. and according to the math is is. but if we are going for the math then we need to scrap all past coils.. and use the math...
thats the direction im going...
making "Markos" coil...  we can call it a "VBM math defined coil "
but like i say if we really did ti correct we need to scrap the 11 former version. but that leaves us with...
for a 36x36:
12 coil bundles
12 wires each = 144 wires, x 2 for each end = 288 wire ends!
what kind of madness is that.
so we use 11 former's so the twist moves over and the wire can continue.
any how thats technically wrong.... if we want to build a "VBM math defined coil "
« Reply #392, on July 18th, 2016, 11:23 AM »
also for all of those who have the old former's ( the ones Matt made, 007 stile) , here is the ring clip i said i would post, ( thank to Jim for drawing it)
again it goes on before you start winding, then just turn it as you go, will hold the wore in place ( not sure how well tho. )
jeremy gwilt
« Reply #393, on July 18th, 2016, 05:53 PM »
not much going on...i have to get the second winding finished properly yet.
whatever is causing the coil to ring, the beginning is timed with the IGBT on time. lots of things affect the 'ring', but it may be the coil itself setting the frequency initially....??  it is strange that the coil picks that pulse up so much stronger than the 1000v+ standing waves its being bathed in......at least i find that strange.
https://www.youtube.com/watch?v=tSj6UGQwjT0&feature=youtu.be
PJ
« Reply #394, on July 19th, 2016, 12:46 AM »
Quote from ~Russ on July 18th, 2016, 11:08 AM
I think I will use this file to see what you are trying to achieve in your latest design - i couldnt quite understand the text description you gave :P
I'm using my phone to view this site and downloding the .zip file returned an error so I will try log in from my laptop and download it from there
Quote from ~Russ on July 18th, 2016, 11:12 AM
Thanks
That is probably the best part of the model I made :)
Once I've looked at the file you posted I'll let you know if I can model something for you
I'm still thinking of trying a 36 x 45 phi torus - I might start a new thread for this to keep this thread more clear for your work
Keep up the good work!
PJ
« Reply #396, on July 19th, 2016, 10:12 AM »Last edited on July 19th, 2016, 10:17 AM
Some photos of the new Phi tori.
This is hole of 90mm.
 Former is 145.575mm
total OD is 381.15mm when assembled... ( 15"!)
It's a monster. But man it will look cool.
This is a 36 slot . 11 formers.
Wire should go through the hole 2 times. The wire path is not the same as 007.
This will be more like the 36x36 number map.
Any how. Don't get confused. This is still not 100% with the math. Becuse of the 11 formers.
Attached is the orgnial former and ring Matt made.
The smaller unfinished coil is same OD as the 007 coil but PHI based. (this the one that the wires are too tight.
And the big one is PHI based but 90mm ID.
thanks to Jim for drawing it up. And we used PJs angles slot idea but just used an average angle.
We had to make the ring smaller to fit in the bed!  Haha
HUGE :)
I'm loving it.
Will post STL files shortly.
