Hy warriors
I tried this on pixlr.com
Maybe it helps.
Congratulations for this wonderfull work
i am with you
...from brazil.
Maybe it helps.
i am with you
...from brazil.
I don't known. But the thickness of the wire and the ohms concern me. Guess it's better to have more wire then not enigh. ??
For now. Is it invert and flip my immage and it will be the right direction.
Guess I'll be rewinding my coil. Lol.
It won't help you 3DP guys, but I can certainly make a CNC version that is much bigger--12 inch ring and 9 inch bobbins. You'll need some wire for that monster, which will bring the resistance up. Could easily get the 36 bobbins holes for the gap that we are supposed to have too.
Has Marko given any reason why this coil can't scale up?
I haven't ordered the plastic yet--considering using 3/16th instead. Just finished producing the G-code which should take much less time to run and cut all the parts. Pretty certain I can have everything done in an evening.
Let me know if you think I should deviate from 007's version.
007's is the same as daniaels. So it's a good size I think. Its just the amount of conductors that I want to change...
I'd go to 18 then and short 9 of them.
I still say we can just add a big single conducter at the core of need be. Is we can do parallel
i was wondering about this as well. currently my L1 is 24 strands of 28awg but i wanted to throw 1 or 2 strands of 22awg in for the 'core'. i can already tell that ill be making a second coil at some point as well.
