« Reply #200, on June 11th, 2016, 08:00 PM »
Quote from Viking on June 11th, 2016, 03:00 PM
Does anyone know an antenna design guy that can take a look at this antenna / elaborate transmission line design ?
Would be helpfull with some input from somone that is experienced in that specific world of black magic.
yeah anyone in in that impedance matching and everything else complicated could join that would be amazing...
Quote from Viking on June 11th, 2016, 05:53 PM
Hello All,
Reviewing the 007 demo (who was "Q" in that one :P): 007 says that apart from the 2x6 "shorted" strands, the rest "is pretty much like Daniel", which when reviwing his (their) youtube videos show that the coil is continued (and not going back or opposing).
There is a lot of ampere*turns missing, which could be running in the 2x6 strains if they are really shorted.See enclosed drawing.
Also enclosed is a quick sketchup and calculation of the Q value, judging from the measured increase in voltage at the output, Q is 4.7 - which is on the average.
please help us non electronic guys understand why the Q is important. what is the Q and why do we care :)
i know we talked about it but 99% of us here have know idea...
nice calculations
« Reply #203, on June 12th, 2016, 02:07 AM »Last edited on June 12th, 2016, 01:19 PM
Goood stuff. I have an SWR meter. I wonder what frequency is was...
Also I had some results today. I believe I was seeing the results that 007 was seeing with the LED bulbs. And I seems that yes. There is a meter trick. But there is more to the story.  We have some work ahead of us.
Long story short. Its all about the power factor. When my video gets done il post it so everyone can see what I see and tell me if I'm musing something or what.
For now. This is a great way to understand the basics of power factor.
http://www.allaboutcircuits.com/textbook/alternating-current/chpt-11/calculating-power-factor/
Viking
« Reply #204, on June 12th, 2016, 09:00 AM »Last edited on June 12th, 2016, 04:58 PM
Here's a PDF with some of the concepts and math about parallel and series resonance and the Q value.
Q is a Quality factor. It's the fraction of stored energy in a system to the amount of energy lost per cycle. So what we want is negative Q's :-)
Q is defined for inductors, capacitors and LCR systems. It also exist when talking about other systems than the electric ones.
Another concept to be aware of, are the concepts of the frequency contents of a waveform. See: https://en.wikipedia.org/wiki/Fourier_series
For.example a 50% duty square wave have odd harmonics contained within it. If it has a basic frequency of X Khz, it also has 3X, 5X, 7X etc. components of decreasing amplitude (same factor). If the duty is not 50% there will be even frequency components as well.
Secondly one has to know something about the propagation of waves in transmission lines, which are conductors with a distrubuted inductance and capacitance (meaning they have a L and C per length - like the vortex coil). The interesting cases are the cases where standing waves are occurring, as they can increase the energy contents like the RLC circuits and have peaks and nodes where current flow is maxium and zero and the same for the potential difference (voltage) though not in the same positions. It also creates interesting discontinuities at the ends of the transmission line, like when moving a whip to make a cracking sound.
https://en.wikipedia.org/wiki/Transmission_line
Finally the concept of impedance matching, which is another word for obtainig the resonant condition,which is also the condition for maxmum energy transfer between systems. Those concepts are generally used in any system where waves occur.
https://en.wikipedia.org/wiki/Impedance_matching
There's of course lot's more..
But have in the back of our minds, that our general taught concept of what electrons are, how they flow through wires and how induction really works, is most likely fundamentally wrong. That's why we don't know what the origin of gravity is (well some do..) and why things have mass. We don't understand the concept of time either. We are told (..) that time is not really progressing linearly, but to us it appears so. It is more of a type of field, like electric and magnetic fields. We also don't know how the atoms really work.. Hurray !! ;-)
Volty
« Reply #206, on June 12th, 2016, 02:35 PM »Last edited on June 12th, 2016, 08:05 PM
Quote from ~Russ on June 12th, 2016, 02:07 AM
Goood stuff. I have an SWR meter. I wander what frequncy is was...
Also I had some results today. I beleive I was seeing theresluts that 007 was seeing with the LED bulbs. And I seems that yes. There is a meter trick. But there is more to the story.  We have some work ahead of us.
Long story short. Its all aboit the powefactor. When my video gets done il post it so everyone can see what I see and tell me if I'm musing somthing or what.
For now. This is a greate way to understand the basics of power factor.
Hi Russ and All,
   Clarify please:
-Are the rev 11 Coil Former / 12 wires of 22 AWG Final?
-007 got 15 Ohms shorted or not and why can't you just ask him?   http://open-source-energy.org/?topic=2680.msg37169#msg37169
 -Matt still advises 18 strands so they could be divided evenly, all to satisfy the needy Audio Amp's 4 Ohms Minimum need, else this Lossless Clamps schematic because it cares not about Ohms of the Load?
http://open-source-energy.org/?topic=2680.msg37239#msg37239
These former files are for 12 strands of 22 AWG?:
-stl's files on Pg 4:  (A new friend here may be able to print me some)
   http://open-source-energy.org/?topic=2680.msg37130#msg37130 (rev 11 stl's)
   http://open-source-energy.org/?topic=2680.msg37138#msg37138 (3D pdf Thanks Matt)
-stk CnC's files on Pg 5:
-dxf Laser cut files here Pg 8:  (I sent a couple RFQ's to San Jose area shops for masonite or acrylic cutting)
http://open-source-energy.org/?topic=2680.msg37266#msg37266
different size poe Large Coil Form from 1Stop:
http://1stopenergies.com/t/frames
Chris Sykes $9 recommended low-cost Audio Amplifier OK???
   Info Source:  https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjohPzKoqPNAhVG-2MKHf3cCeMQFgghMAA&url=http%3A%2F%2Fwww.hyiq.org%2Fdownloads%2Fguidelines%2520to%2520Bucking%2520Coils.pdf&usg=AFQjCNGg_icJWzYEq7DYzzNBlOyUPbTIJw&sig2=Jfymrt9ps1ByJB6HZ3GnVQ
http://www.ebay.com/itm/Mini-180W-180W-2CH-12V-Small-Stereo-Audio-High-Power-Car-Amplifier-for-CD-MP3-/231972966569?hash=item3602aa90a9:g:5sIAAOSwgQ9VpdGs
   This LvPin unit's Spec's are:
Features
    Weight: 250g
    Size: 6" x 4" x2"
Specifications
    Power output: 180W
    Input voltage: 12V-18V DC
    Output impedance: 4ohm-8ohm
    Frequency response: 100Hz - 20kHz
    S/N: 85dB
    T.H.D: 1%
Russ your last post says results are like 007 LED resistive LEDload, and you can see this is about power factor, PF.  Everyone please study these two lessons from Luc.
Note where in these two videos how to see the Volts Vs. Amps on the Scope using a 0.1 Ohm resistor. Luc Choquette shows his motor running itself on reactive power in Part 2.  Note the parabolic return as Voltage increases.
   From 110VAC he harvests 20 Watts, from 220VAC he harvests 90 Watts, and he says we need a generator od 600VAC and we are talking some practical PF harvesting indeed.
   https://www.youtube.com/watch?v=8Hr2C1vvvx4 <--Reactive Generator Tutorial Demo 1
   https://www.youtube.com/watch?v=g6SaAjQaLkM <--Reactive Generator Tutorial Demo 2
 US smart Power Meters cheat us by always charging PF = 1.0.  This will help those turning their own generators though.
   About Q, when looking for max amplitude resonance, low Q is where it is hard to see that peak amplitude at resonance.  It barley changes.  With one toroidal "Loop" of wire, it is so so, BUT with an adjacent identical conductor, stacked above, not even connected, the Q rises exponentially, and resonance point becomes profound, sudden, and massive easy tuning to find it.
   This is why twin lead is used as a Magnetic Pick-up for an O Scope to actually see inside the coil length.  A single wire coiled into a pancake will NOT drive your O'SCope.  A twin lead will, where you use a length rolled up into a double layer Cinnamon Roll, and connect to the outside of just one lead, the other totally floating replicates the adjacent pulsating or resonating magnetic field, without loading the source, and vica-versa...  The unconnected half of the twin lead amplifies itself into the twin with one end connected to the scope.  If you drive an open-ended long solenoid coil with impulses, you can use this pick-up to see the impulses at one one turn into perfect Sine Wave 1/4 wave resonance at the other end.  Perpendicular wires on a toroid allow it to operate as a TMT, with adjacent segments driving for free across the toroid, and can be undulated to make it rotate with 3 phase timing and an even number of segments.  Doing these things i saw only certain integer number of Sine nodes can exist in a toroid, and is also why Electron orbits snap to sudden different radius, as they travel in Sinusoidal pattern, and only integers fit it.  Only certain frequencies will fit a toroid's circumference.  Those long wires outside the torus may be an issue.  The parallel shorts are one length, but the series connected are another length just by how much is inside the torus and how much is hanging outside for connections purposes, way long and concerning me.
Driving tpu open ended torus coil segments this way is how i learned CCW coil winding needed for Northern Hemisphere, as in Steven Marks.  Driving the CCW end yields Unity voltage across the ring.  Driving the CW end, letting the CCW end wag like a stick, yields massive gain.  Go figure why our toilets flush one rotation only.  A 5V p-p square wave open ended drive of that BB style MicroMetals core tpu into the CW end of a CCW segment yields 600V p-p across the ring at f-res x1.0.  At f-res x 1.5, that segment across the ring turns off and both its neighbors resonate for free at this voltage and higher, open-ended, but at 1.5X f-resonance, this is Scalar resonance and not Faraday shield-able, and is also BOGO or buy one get two free, that will get you found and punished, just because they can.  Note the Earth resonates at 7.8 Hz, and the ionosphere at 11.7, exactly 1.5X difference between the two resonance behaviors seen in a toroid with perpendicular wires.  HAARP is not Faraday shield-able either.  Perpendicular wires couple only the Capacitive, the impulse or overshoot, the scalar component.  Parallel wires couple inductively.  45 degree rotation may be a worthy adjustable LC tuning method...  I notice the POE is perpendicular.  If you make that magnetic pick-up, stick in in a bean can and rest it on the coil, you see the whole square wave.  When you ground that can, the overshoot at rising and falling edges, the impulses you will see are NOT Faraday shield-able.  They pass right through the grounded can centered on 0V, and the rest of the square wave disappears because this portion is Faraday shield-able.
jeremy gwilt
« Reply #207, on June 13th, 2016, 09:45 AM »
for my part, i have started driving L1 with a square wave oscillator (50% duty) and IGBT. L2 has capacitors directly across the coil to form a tank (ish ) circuit, a FWBR, 2200uf cap and LED load.
by adjusting the tank capacitance and frequency, i have started tuning until L2 has a nice clean sine wave across it (point of resonance). this is just to start a baseline for myself, and give others a point to go from. once i get a bunch of data , i will start a separate thread to share it.
for example:
at 6 volts, tank capacitance is .1125uf, frequency is 9.5kHz.
12 volts,   it is .862 uf and 6.75kHz.
these could be simple harmonics of resonance.
« Reply #208, on June 13th, 2016, 11:37 AM »Last edited on June 13th, 2016, 11:55 AM
more testing, first video is jsut me making the LED load banks
https://www.youtube.com/watch?v=JQ19koKrrFI
the second one is me testing some ideas with the LED banks and some other stuff with analog meters.
https://www.youtube.com/watch?v=JrH0pfOUSRI
ok i defiantly demonstrated the effect of OU in that last video if you had just a scope and meters... and that's with out a load even... however the power analyzer on the scope shows another story...
what dose this mean. not sure just yet. still a lot to do and understand. if there was a way to keep this resonance going and change the phase angles it might be possible to extract some of that energy with out disrupting the system. that's what i understand the DC-DC converter did for 007. but we are not for sure at the moment.
don't forget I'm not coil shorting, and there is a piece of the key in there i believe. i need to wind another coil...
if some one goes through the videos grab some screen shots and post them with a short description on what i was doing at that time. sorry i just haven't the time to do that at the moment..
feed back please
« Reply #209, on June 13th, 2016, 11:46 AM »
Quote from Volty on June 12th, 2016, 02:35 PM
Hi Russ and All,
   Clarify please:
Features
    Weight: 250g
    Size: 6" x 4" x2"
Specifications
    Power output: 180W
    S/N: 85dB
    T.H.D: 1%
hello Volty, i will study  Luc.'s work, i know he went through this type of work a while back. some good work there for sure.
on the rest of your questions i will need to sit down and try to reply to them all, but for now,
3d print former 9 is ok, we plan on making a change when time allows to make them more sturdy but they work for now,
ring 10 is solid and 11 has holes, ether one works,
Jeremy offered to sell the former's and rings at cost. just see earlier posts
as far as wire, driving circuits , coil shorting... its all up in the air at the moment.
ok, sorry i can go in to much detail at the moment. no time, but once we learn more i will post more, for now watch the live feeds videos i have been posting to get ALL i have done.
« Reply #210, on June 13th, 2016, 01:23 PM »
Russ, if you can, please add another pair of analog meters that monitor the input to your amplifier.  I'd like to see a comparison/efficiency of the amplifier itself.
Also, run all your LEDs in series if you can get enough input voltage to make them initially illuminate.
All I can think of for the moment.  Gotta run.  Be back later this evening.
talisman
« Reply #211, on June 13th, 2016, 04:42 PM »
Hi Russ
I see a sunflower pattern put in a donut shape with some standing fan screens. Just snip out the cross hatches and connect.
If a manufacturer can do this with steel they probably can with copper. I am thinking about graphite or graphene effects in the
core or coating. Anyway another day.
« Reply #212, on June 13th, 2016, 05:57 PM »
Quote from Matt Watts on June 13th, 2016, 01:23 PM
If this much works, I really think you should consider a light-box for power recovery until we can better understand what 007 had done to that special high voltage input PSU.
jrodney55
« Reply #214, on June 13th, 2016, 07:33 PM »
Quote from ~Russ on June 13th, 2016, 11:46 AM
Hey Russ I'm available anytime to help you & Matt with continuing CAD design if you want - just let me know what you need.
« Reply #215, on June 13th, 2016, 10:19 PM »
Russ, attached are the extensions you wanted on the former bobbin.  Let me know if this is what you were thinking.
Had to zip the STL file--getting a little big with all the customizations.
« Reply #216, on June 14th, 2016, 03:22 AM »
Quote from Matt Watts on June 13th, 2016, 10:19 PM
yes Sir, that's it! that will make this a lot more stable. i wander if we should go even more... himmm, ill test this out with one and see what happens. but YES THANK YOU MATT
i will call thses the final versions and remove all the rest ( or at lease update the first post with this one it)
also, marko posted this video:
https://www.youtube.com/watch?v=zyR8FRXqInk
« Reply #218, on June 14th, 2016, 03:26 AM »
Quote from jrodney55 on June 13th, 2016, 07:33 PM
thank you Jim, yes, honestly i forgot. ( shame on me) but yes i will remember, not sure why i forgot... hummm. long days / nights i guess lol
« Reply #219, on June 14th, 2016, 03:55 AM »
Ok. Second coil done. This one clockwise.
24 strands of 23awg in each coil.
This will give me around 6 ohms. And the bundle will give me 12 and 12. 12 in searies will be 6.1 ohms estimated.
I used this as a how to demo. So I'll upload that soon.
Now the wire thickness looks closer I think.
007 could have ment 12 as a set. And not 6. This looks better as far as wire thickness.
If some one can over lay this photo to 007 that would be greate.
« Reply #223, on June 14th, 2016, 07:20 PM »Last edited on June 14th, 2016, 07:33 PM
Thank you jim
So dose the wire look closer to 007's ?
So today I brought my scrap to get some funds for this project. Near by was the apex superpluss store.
Check out this place.
http://www.apexelectronic.com/image/
I was there for allmoat 2 hrs with my son. All we Did is Rome around. And WOW. I knew this place was here but ignored it for 2 years.
I'm still puzzled. Photos do not do justice.
Any how. They wanted a bit more than I wanted  to pay for some caps. So in the far corner there is some crap outside quite wethered. But I found some old boxes and rolls. I asked for the hole box.. There is about 600 if them in there. At about 6.5 cents each it was a good deal. I can make a bank and make them switchable so I can try diffrent cap sizes. 10 in series  and 3 of those banks in parall is .15uf. Same as 007.
The caps I have have internal resistors in them. That's not ideal.
Then in can make other banks to play with diffremt frequncys.
The spool of caps was .033uf. There was around 1500 or something on a roll. But the .3uf will work better for this.
I also got a spool of wire. It Looks silver plated copper. I wanted to make a really good coil with this and try it.
I also got some 1n34 germanum diodes. 50 of those i can make a .5amp FWBR. I have some ideas to try.
WOW.
