hey, welcome Joe, so i don't get hissing or ozone ( not that i can smell ) but do get a nice buz from the coil. i think i smelt some ozone but not much, not like i would think, that could be due to the coil configuration. and wiring setup.
you say 300-500V is that RMS voltage? if using DMM i would say yes. ???
also feel free to share your experience more. i know you have played with theses a lot.
geg, thanks for the files. like i was saying before if you use 12 you will be more on par with the math, however you will end up with Manny more coils ( 6 or 12 to be correct) and that is why we use the 11, it makes for a single wind around the torus.
geg
« Reply #350, on July 8th, 2016, 07:22 AM »
