Hello jbignes5,
I seriously think you are stumbling around in your theories - whereever they originate.
The torus is indeed a universal shape and path for energy flow in the universe.
Also black holes also seem to play an important role in galaxies, planetary systems, individual planets and right down to the atomic structure.
The atom has an aperture in the center of the group of nucleons through which ether energy flows, creates and stabilises the atomic structure. Relative simple calculations confirm this concept by it's ability to reproduce known natural constants and both measured and theoretically calculated (via QM) dimensions.
Regarding your field shape based on the Rodin sequences, the toroidal mapping has been available on the internet for many many years. So you obviously have not been paying attention to developments.
Regarding the current flow in the rodin or vortex coil, which is more like a transformer, I have never seen an electromagnetically based OU device that did not use the principle of seemingly opposing magnetic fields. This I am convinced, it must certainly also be the case here.
007 was doing his best (as is apparently common practice) to obfuscate important points in his presentation and most likely also hiding important details in order both to be able to gain somethig himself (which will probably lead in a bad direction) and to only allow certain people to use the technology. It has been the case in the past and so it will apparently continue to be.
