Looks like you almost have it webmug.:cool::D
Far from it, this is only just the beginning. :cool: :D
Br,
Webmug
Hi Jeff,Quote from Jeff Nading on May 16th, 2012, 05:28 AM Looks like you almost have it webmug.:cool::D
Br,
Webmug
Im sure half of you got this e-mail from Jameco but I figured Id post it any way. "Design an electronics project, we’ll kit it and pay you a royalty every time it sells!" Maybe someone could make a VIC kit so that newcomers and stuff can more easily get started! Heres the link: http://links.enews.jameco.com/servlet/MailView?ms=NDA3ODgxMgS2&r=MTk3NzMxMjY0ODkS1&j=MTI1MTM2MDU3S0&mt=1&rt=0
Hi Faisca,
pll pin14. pulse 16.6kHz from my waveform generator as refIn I could lock-in with the circuit from Sharky. If the pulse was below or higher than the vco settings (R1,R2 C1-2) then the scanner is on free-run, no lock. (PLL VCO voltage min. to max. to min from the scanner)
https://www.youtube.com/watch?v=0VCLCG_6I18
You can see when I change the RefIn pll pin14. input signal in frequency the pll locks-in.
Blue is pll pin3. signal Yellow is pll pin4 Fout.
Second part is the yellow signal at the TIP120 SIG_PRI.
First I wanted to build the "cell driver circuit" from Stan but I can not make it work.
Perhaps you are able to make it work. For now I use the BC556 driver for the TIP120.
https://www.youtube.com/watch?v=s5KQn8oVDpo
Here you can see the Gating active, the pll tries to lock but it fails to keep it locked in the gate time and tries to lock-in again after inhibit is disabled. Yellow is the feedback signal from the opamp. Don''t mind the pulse shape it is not perfect! Should be 50% block pulse I guess.
All this I build on a breadboard. This is what I have so far...
Br,
Webmug
I'm sending the diagrams of the two versions that I have succeeded.
All this I build on a breadboard, too.
"v1" Pseudo Meyer, somewhat modified.
"V2": The same, without scanning (not needed) operates automatic.
Have fun.
I'm re-sending the diagrams of the two versions. Now, very well.
Don't know for sure, but I think the scanning is needed when the gate is active.Quote from Faisca on May 18th, 2012, 02:29 PM I'm sending the diagrams of the two versions that I have succeeded.
Have fun.
Russ, Sharky, do you got time to test the pcb and post some info?:D
Br,
Webmug
cores will be in next week... then i can do some real tests.Quote from Webmug on May 19th, 2012, 01:20 AM Don't know for sure, but I think the scanning is needed when the gate is active.Quote from Faisca on May 18th, 2012, 02:29 PM I'm sending the diagrams of the two versions that I have succeeded.
Have fun.
Br,
Webmug
at the moment, when i turn on gating it kinda skips around. it seems to act odd.
but it dose lock on at a very low frequency. this is with an iron core. so the ferrite will be a huge help...
do you need me to still test the output of tony's circuit like you asked before? and if so. what did you need me to test?
tanks! ~Russ
PS. keep up the good work and ideas guys! its grate to see everyone getting along! ;0
Have fun.
Br,
Webmug
hello Webmug.
You are right in the pcb Meyer. Not in this topology (v2), which I presented, it is not necessary. In this, you can use the gate (pin 5, on/off), and always will be locked, only taking one cycle or less.
But in the version with scanning (v1, like the Meyer), the same test was bad and often taking longer, locking wrong.
Maybe I'm wrong, in the form of testing.
How do you testing this?
See my test provisional.
Hi Faisca,Quote from Faisca on May 19th, 2012, 08:04 AM hello Webmug.
I test it with my VIC feedback coil and circuit (AC=resonance) and a waveform generator set as pulse (bypass the opamp)
Getting resonance on the secondary coil at 16.6kHz with Sharky ("meyer") circuit.
http://open-source-energy.org/?tid=311&pid=4798#pid4798
Br,
Webmug
Good night, folks.
I made many tests with the PLL and gate pulse, but did not like it very much. I'll show some pictures.
The results more similar to our objective, we obtained shortening the gate and also scan for 55ms.
It's not perfect, and very unstable to catch, I think this diagram and pcb of S.Meyer shown, are not good, perhaps a prototype failed or changed to misinform (still can not believe that the MIB will allow this).
Anyway I think we got the idea, just have to re-shape it to work.
Tomorrow I will do the same tests (with gate) using my version uC.
See you soon.
I'm showing a test done with PLL dphi 90 ° uC.Quote from Webmug on May 20th, 2012, 02:10 AM Hi Faisca,Quote from Faisca on May 19th, 2012, 08:04 AM hello Webmug.
Br,
Webmug
Notice when I change the capacitor, with what speed is locked in the new frequency.https://www.youtube.com/watch?v=etYHZbGfgIo
Yes, Russ!Quote from ~Russ/Rwg42985 on May 19th, 2012, 03:03 AM cores will be in next week... then i can do some real tests.Quote from Webmug on May 19th, 2012, 01:20 AM Don't know for sure, but I think the scanning is needed when the gate is active.Quote from Faisca on May 18th, 2012, 02:29 PM I'm sending the diagrams of the two versions that I have succeeded.
Have fun.
Br,
Webmug
tanks! ~Russ
The output of Tony's PCB if you can test it, would be great (it's a good pcb but I have not managed to get it to work)
Compare PLL output pin4. with cell driver output at the TIP120 where the pickup is and after the resistor cap going into the PLL again Pin3.
If you can compare Tony and sharky pcb's would be useful. Why, because of the 50% duty-cycle thing. :cool:
Yes ,the resonance frequency with iron core is very low compared with the ferrite.
The settings on Sharky pcb are for higher frequency so getting resonance with the iron core you have to change the cap and R1,R2 resistors. (voltage should be very low on resonance with iron core :D)
Thanks!
Br,
Webmug
Russ,and others can you help me ?I am confused with the transistors on the VIC card:
2n2222 to-18(metal case)=is only NPN or is PNP too? because the B,C,E on the cell driver is different from the others,which are wich?
hi webmug.
But if you have used the generator, its vic locked with the generator. This proves nothing, only copied the PLL frequency of this generator.
Why not use the coil FB? Where the loop/link is closed?
I'll build a transformer vic (or the closest) and continue with the tests. Still, I think that for proof of my PLL resonance is sufficient to test the concept.
Success for us.
Hi,Quote from adys15 on May 25th, 2012, 02:04 AM Russ,and others can you help me ?I am confused with the transistors on the VIC card:
The 2N2222 is an NPN type.
TO-18 is the metal can type. TO-92 is the plastic type.
The 2N2907 is an equally popular (PNP) transistor complementary to the 2N2222.
The 2N3904 is an NPN transistor that can only switch one-third the current of the 2N2222 but has otherwise similar characteristics.
Br,
Webmug
Thanks Webmug,I know the 2n2222 metal case is a NPN but ,look at the att,my drawnings are corect? look at the secound 2n2222 starting from bottom of page on the cell driver that is PNP? because it has B,C,E and othets metal case 2n's has B,E,C writen on the pcb..please reply
Hi,Quote from Webmug on May 25th, 2012, 03:09 AM Hi,Quote from adys15 on May 25th, 2012, 02:04 AM Russ,and others can you help me ?I am confused with the transistors on the VIC card:
Br,
Webmug
Yes, I see something is different with the placed 2N2222.
I think the base (middle) was bend to the other side in the pcb. looks like it is a different type but it is the same 2N2222. 22 is readable from side view. Can't find other NPN with xNxx22???
Br,
Webmug
Can you guys tell me if i done the corect conections on the VIC card I trace them with Don's spec's,please corect me, i'm confused with the baterry pozitive is on pin 3 top,and also pin 5 top/bottom...Tony would know beter because he design the skematic:D ,so Tony if you can corect it please see att
Be careful, at your schematic the D6 D7 diode types are interchanged, compared to stans original.Quote from adys15 on May 26th, 2012, 10:19 AM Can you guys tell me if i done the corect conections on the VIC card I trace them with Don's spec's,please corect me, i'm confused with the baterry pozitive is on pin 3 top,and also pin 5 top/bottom...Tony would know beter because he design the skematic:D ,so Tony if you can corect it please see att
