i finish to assembled a different board
Did you get it to work?
Good job btw :)
Have you tried it?Quote from Jean-Alexandre on October 29th, 2012, 02:40 PM i finish to assembled a different board
Good job btw :)
Yes of course! I am doing coiled (coil style 1 of stan meyer).Quote from Lynx on October 29th, 2012, 03:19 PM Have you tried it?Quote from Jean-Alexandre on October 29th, 2012, 02:40 PM i finish to assembled a different board
Good job btw :)
It's not easy... 3000 spire x3 + 500 + 500 :(
If you have a coil winder under arduino. I am interest.
Alex
Thanks!Quote from Jean-Alexandre on October 30th, 2012, 08:22 AM Yes of course! I am doing coiled (coil style 1 of stan meyer).Quote from Lynx on October 29th, 2012, 03:19 PM Have you tried it?Quote from Jean-Alexandre on October 29th, 2012, 02:40 PM i finish to assembled a different board
Good job btw :)
Alex
Do you also have a WFC ready?
Does it produce hydrogen?
Please let us know how you're doing :)
OkQuote from Lynx on October 30th, 2012, 08:33 AM Thanks!Quote from Jean-Alexandre on October 30th, 2012, 08:22 AM Yes of course! I am doing coiled (coil style 1 of stan meyer).Quote from Lynx on October 29th, 2012, 03:19 PM Have you tried it?Quote from Jean-Alexandre on October 29th, 2012, 02:40 PM i finish to assembled a different board
Good job btw :)
Alex
My contributions to the project of Stanley Meyer on picture
In this moment I'm just playing with your progress in the domain. But once my coil is finished.
I might be in annoncer result or not :)
https://plus.google.com/photos/109596636524884382415/albums/5804848306524471601?authkey=CN--0rrfrcyoUQ
https://plus.google.com/photos/109596636524884382415/albums/5744373964356251873
Alex
Looks like some really good work there Jean :cool::D:PQuote from Jean-Alexandre on October 30th, 2012, 02:24 PM OkQuote from Lynx on October 30th, 2012, 08:33 AM Thanks!Quote from Jean-Alexandre on October 30th, 2012, 08:22 AM Yes of course! I am doing coiled (coil style 1 of stan meyer).Quote from Lynx on October 29th, 2012, 03:19 PM Have you tried it?
Good job btw :)
Alex
Alex
Good job btw :)
Alex
Alex
some nice work as normal!!! thanks for sharing!! :)Quote from Jean-Alexandre on October 30th, 2012, 02:24 PM OkQuote from Lynx on October 30th, 2012, 08:33 AM Thanks!Quote from Jean-Alexandre on October 30th, 2012, 08:22 AM Yes of course! I am doing coiled (coil style 1 of stan meyer).Quote from Lynx on October 29th, 2012, 03:19 PM Have you tried it?
Good job btw :)
Alex
Alex
also "If you have a coil winder under arduino. I am interest."
jeff, where is that ardino winder software that some one wrote?? we need to move it to the open projects part of the forum... so others can find it!! ~Russ
Hello all,
Just a last question.
How pluged a rang_frequency potentiometer (ref image).
The wire on pin of potentiometer ?
Pin on potentiometer.
A B C pin
1 2 3 4 5 6 7 8 9 10 11 12 pin
Someone have a schematic ?
reference of pot on farnell:
1123704
thank you :)
PS: sorry for a quality of image :). Father Christmas would bring me a new one.
I cant see clearly but if you have one pin in the middle that is the ground,and the rest are frequency inputs,just in lawton skematics,where he uses rotary pot on the caps for rangeQuote from Jean-Alexandre on November 6th, 2012, 02:46 PM Hello all,
A B C pin
1123704
thank you :)
look, if that is a 4 way switch, the A is associated with pins 1 2 3 and 4, B is associated to 5 6 7 8 and so on.Quote from adys15 on November 7th, 2012, 02:39 AM I cant see clearly but if you have one pin in the middle that is the ground,and the rest are frequency inputs,just in lawton skematics,where he uses rotary pot on the caps for rangeQuote from Jean-Alexandre on November 6th, 2012, 02:46 PM Hello all,
A B C pin
1123704
thank you :)
for sake of clarity in the 1 position A is connected to 1 B to 5 and C 9
regards
A B C pin
1123704
thank you :)
regards
I don't understand how pluged potentiometre range_freq on sharky board.Quote from sebosfato on November 10th, 2012, 04:49 AM look, if that is a 4 way switch, the A is associated with pins 1 2 3 and 4, B is associated to 5 6 7 8 and so on.Quote from adys15 on November 7th, 2012, 02:39 AM I cant see clearly but if you have one pin in the middle that is the ground,and the rest are frequency inputs,just in lawton skematics,where he uses rotary pot on the caps for rangeQuote from Jean-Alexandre on November 6th, 2012, 02:46 PM Hello all,
A B C pin
1123704
thank you :)
regards
I have 5 positions in a sharky board (1 2 3 4 and gnd)
and the potentiometer: A (1 2 3 4) B (5 6 7 8) C (9 10 11 12)
I chosed A1 B5 C9 ? but how pluged ?
Potentiometer|Sharky Board
[A1] => |1| RANGE
[B5] => |2| FREQ
[C9] => |3|
??? 4|
??? 5|
or
[A] => (1)
[1] => (2)
=> (3)
[5] => (4)
[C] => (5)
[9] => (?)
or
[1] => (1)
[2] => (2)
[3] => (3)
[4] => (4)
[A] => (5)
thank you for answer
You may have answered this by now but, it's a good time to bring this thread back to the top.Quote from Jean-Alexandre on November 17th, 2012, 07:55 PM I don't understand how pluged potentiometre range_freq on sharky board.Quote from sebosfato on November 10th, 2012, 04:49 AM look, if that is a 4 way switch, the A is associated with pins 1 2 3 and 4, B is associated to 5 6 7 8 and so on.Quote from adys15 on November 7th, 2012, 02:39 AM I cant see clearly but if you have one pin in the middle that is the ground,and the rest are frequency inputs,just in lawton skematics,where he uses rotary pot on the caps for rangeQuote from Jean-Alexandre on November 6th, 2012, 02:46 PM Hello all,
A B C pin
1123704
thank you :)
regards
[A1] => |1| RANGE
[B5] => |2| FREQ
[C9] => |3|
??? 4|
??? 5|
or
[A] => (1)
[1] => (2)
=> (3)
[5] => (4)
[C] => (5)
[9] => (?)
or
[1] => (1)
[2] => (2)
[3] => (3)
[4] => (4)
[A] => (5)
I think you are asking about the P7 connector on the board.
schematic shows 1,2,3,4,5 and you have a rotory switch to connect. The switch has 3 "polls" meaning sections that are electrically seperated but mechanically activated at the same time. Meaning when in the CCW position "section" A is connected to pin 1, "section" B is connected to pin 5, etc. When in the next detent CW "section" A is connected to pin 2, "section" B is connected to pin 6, etc. You will only use "section" A.
You need to Connect
P7-1 to rotory switch pin 1 >From U14B-4
P7-2 to rotory switch pin 2 >From U14C-6
P7-3 to rotory switch pin 3 >From U14D-8
P7-4 to rotory switch pin 4 >From U14E-10
And
P7-5 to rotory switch pin A >Output to U15-1
Thanks Russ! I should have released all this info sooner, but like you said in your video today, sometimes we do stuff that we later regret. I had planned on releasing this months ago but I didn't want my guy Spencer to be mad at me about it cuz we worked on a prototype version of this together March of last year. Before we purchased the photo's from Don back last year, we had already figured out all the IC's used, all we needed were the correct resistor & capacitor values in the circuit. I will probably continue to sell the bare VIC Circuit boards with no components on my site for around $50 each, which that isn't a bad price at all.
Well if theres anything I can help ya with just let me know on here or drop me an email at tonywoodside@gmail.com
Hi Tony,Quote from TonyWoodside on March 27th, 2012, 11:39 PM Thanks Russ! I should have released all this info sooner, but like you said in your video today, sometimes we do stuff that we later regret. I had planned on releasing this months ago but I didn't want my guy Spencer to be mad at me about it cuz we worked on a prototype version of this together March of last year. Before we purchased the photo's from Don back last year, we had already figured out all the IC's used, all we needed were the correct resistor & capacitor values in the circuit. I will probably continue to sell the bare VIC Circuit boards with no components on my site for around $50 each, which that isn't a bad price at all.
Did you finally decide to sell just the bare PCM?
Jul.
