bussi04 ,Quote from bussi04 on May 4th, 2012, 06:30 AM if the core gets hot one reason may be that the core runs into saturation. to avoid saturation primary must have a pulse voltage, minimum frequency and core parameter dependent minimum count of windings. primary windings must be calculated in a way that gating is not mandatory.Quote from Webmug on May 4th, 2012, 04:52 AM Hi,
I replaced the waveform generator with the feedback coil.
Did a few tests on the feedback coil circuit. This is more difficult than I thought it would be.
What signal should I get when I have AC resonance at the chokes from the VIC feedback coil?
I'm not getting nice square wave (again 50% duty cycle:D) from the opamp to have a lock-on :rolleyes:
The feedback coil should mirror the signal on the core, right?
So AC is AC at the feedback coil in theory...
NOTE. WARNING !!!
When you are going to test the VIC without the GATE active, the primary coil is getting hot! So use gate! If primary gets 1.1Amps pulsed for a period of time without gating the wire could be damaged!
Br,
Webmug
The core is not getting hot, the primary coil is when you continuous PULSE it with 1.1 Amps (50% DU) at 12V DC. The 30AWG wire is getting warm/hot so you should GATE the PULSE to lower the current feeding the primary at the same time tuning on the chokes (charge time). Lowering the input voltage (VAC voltage amplitude control) at the TIP120 also reduces the current going through the primary coil.
To all,
In scope shot I measured the signal from pin 6 op-amp pickup circuit from the feedback coil.
What are we going to measure? Resonance on secondary, chokes and WFC ??
We need the feedback pulse also to have 50% duty cycle, this is when you have resonance (total resonance etc. ) ??
Happy testing!
Br,
Webmug
« Reply #250, on May 4th, 2012, 03:10 PM »
