Using Stan's Vic and the numbers Don gave us as and example, I will attempt to show how to impedance match it all.
Question is what is the purpose of Impedance matching?
The answer is Watts in must equal Watts out. (Isn't that right Mr.Watts :clap:)
Hooray! See, I knew I was a part of this whole mess somehow.
Secondary side= 72.4+76.7+70.1+Re78.54+11.5=310 ohms
So secondary coil, plus positive choke, plus negative choke, plus dielectric property of water, plus...
What's that 11.5 ohms? Where does it come from?That's how you do it. :bliss:
Holy cow! The math looks pretty easy, but...
I see some interdependency here that will take lots of do and redo to zero in on the final values. I also see how that very fact enables this circuit to function as it does. It has a built-in feedback loop that will constantly attack the water at faster than the speed of light. If anything changes in the cell, the impedance changes immediately, faster than the water can react. This might be the whole key to it Ronnie. Did you ever consider that?
The turns ratio will force you to recalculate the resistance of the wire you use to get that many turns, and...
The resistance of the wire you spin on the bobbin will force you to recalculate the turns ratio.Hmmm... This could turn out to be a little bit of a pain in the butt.
Ronnie, didn't you mention to me a while back that the
turns on the chokes need to match the turns on the secondary? So if I was to adjust the secondary, to get the right turns ratio, I would also have to alter the turns on both chokes?
That's enough questions for now. I can see why you had a spreadsheet to calculate this stuff.
