ok so now look at this,
this is what the flux from the primary will be doing to the flow of current... Via magnetic flux (right drawing) you can see the blue circle's are places of conflict... where the current flow will be apposing... so looking at it this way, we can see that Pri and Sec are adding in magnetic flux but the L1,L2 are are opposing with current.
the left hand photo is the one from before, it shows the conflict of flow of current vs the magnetic flux. here we can see that Pri and Sec are adding in magnetic flux but the L1,L2 are are opposing in magnetic flux.
so it dose no madder how we look at it. there are apposing things going on here.
by the way this is just if there was lets say DC on the primary... all kinda of other interactions happen when its a "PFN" its a new new animal.
but we need to break it down like this so we can do all the math on it...
by the way dont worry about the "flow" going the wrong way with my + and - signs : )
so now the questions are this, what happens if we break the core? things change... some.. enough that we need to factor that in.
please correct me again if i'm confused. again we some times get lost in our words... but this photo should clear that up...
