ok got my 6n137's in and got things working, there sure are some strange things groin on with all those transistors. but its pulsing...
Matt, schematic confirmed. and you know those - voltage spikes? well i was getting those but only at low voltages. ringing in the coil... not quite like your sim, but still interesting.
https://www.youtube.com/watch?v=4_cPHUhTdAQI connected everything up with the ferite cores. and DRY cell's 6 in series. at first i left a big gap in the core, but then decided to try to stick the closer and Snap... they popped together... and they were stuck that way. takes *some force to pull them back apart. if i drop the voltage lower they do not stick as much, but when the voltage is around 5v or so... they hold really good. that tells me there is some DC bias ALLWAYS. also when really crainking it up around resonance they do not chatter, they just hold firm.... hummm. i also can see this the sig never drops below 2V or so. ( the bottom of the pulse sig) this is by design.
now something to note here is i had a resistor across point where the voltage control is and GND. i cant remember the value, might been a 1k or 10k, i did this because with out it the voltage control dose not work right, when nothing is connected to the output. and i forgot to remove it... should not effect anything tho.
as far as resonance goes, measuring from the "0" point and a cap, i was getting around 150V and on the other i was getting around 100V . this was a nice sighn wave, nothing off set. across the cap i was getting around 45V
my scope is all deffrental and floating... something to note.
the coils set was an old one. i just wanted to see the sig coming from the driver / voltage control circuit.
