Positive.
Build the VIC circuit as we have posted in this thread and scope through each transistor. Until you get to the TIP120, you will see a nice 50% duty cycle. At that final drive is where you'll see the voltage shift that causes the TIP120 to lag at turn-off. As you up the frequency, you'll get to a point where the output of the TIP120 is always on--100% duty cycle. To me this behavior looks clearly by design. It's a linear tapering of the duty cycle controlled by the frequency. What that means is you can precisely control the duty cycle to PPM resolution by adjusting the frequency. And as I mentioned before, my theory is the off-time should sync with the L2 and the on-time with the L1--the L2 being slightly higher frequency (shorter wire length). I honestly think the wire length on those two chokes is far more important than anyone has considered to this point. They control the exact phasing the cell sees. Brettly posted some wavelength numbers in the centimeter range that is critical to water disassociation. So we're talking phase shift frequencies in the gigahertz range.
The wire-lengths of the chokes are equal in Stans Injector VIC, this is designed because the coils are on the same core-leg. The other VIC have their coils on different core legs placed further away from the secondary coil field where the mutual inductance is calculated differently.
So the DU (duty-cycle) should always be 50% for T1-T2.
That TIP only maintains 50% DU if you pulse below 10kHz frequency at 50% DU. Also the hfe drops above 10kHz.
And adjusting the frequency makes no sense changing the DU, the VIC has only one resonant frequency.
~webmug
