BTW, the 22k resistor and 330pF capacitor forms a low-pass filter with roll-off at about 22kHz based on my calculations.
http://www.electronics-tutorials.ws/filter/filter_2.html
adding or subtracting from driver signal?
My findings using this driver is that it only worked pulsing below 10khz. If you go higher 50%du is no longer maintained due transistor bias etc. Way to complex! So designing the cell and coils resonance freq. must be below 10khz. Unfortunately my setup uses higher frequency and i switched to mosfet instead.
~webmug
Matt
Why you dont use Ronnie's driver - it is fully tested and working circuit?
andy
Matt
andy
Simple answer...
Overkill--as Russ alluded to.
Matt i built bouth circuits and worked fine..
what did you use on the J input on amplitude control?
I omitted Figure 4 in my schematic. I don't understand its true intention and behavior yet, where a voltage regulator or a regulated variable supply makes more sense.
Same components reproduce the same results. Do you need new & proper components?
Your circuit is picking up noise, like an antenna.
