also post the sim again I'm installing it...
Notice that down spike is reaching almost 700 volts peak to peak. Crazy stuff. I almost hope it's just the simulator being nuts.
There's another bodge. Regarding that 100uF cap and the transistor beside it. I have not traced.
Correct me if Im wrong...It's not like me to be wrong
GPS has the (SM) VIC (non twin core) on the bench in the back room and is not using the (SM) driver?
From what I have read over the last 2 years...
Most any driver should work for bench testing?
This hobby is definately getting challenging. I keep thinking I'm right there but then find another problem to fix.
Yes, looking at one device that solves dozens of little problems is a daunting task to comprehend and repeat for yourself. It shouldn't be that difficult, but it is what it is and we'll have to get our heads wrapped around it one way or another.
Hopefully when Ronnie gets some of his matters settled, he can give us a booster shot.
1:yes
2:yes
3:yes it helps
4:yes
5:yes and I got more to say about this in another post.
6:got more to say about this one as well in another post.
I just realized the obvious. The 47k & 470 resistors are used to pull each transistor base high or low depending on whether its a pnp or npn. This ensures they shut off completely
The TIP120 apparently does its own pull-down.
because it's a darlington transistor couple.
Speaking of bodges, can you tell where that little red jumper off of the 22k resistor goes? It seems to go under the 100uF cap, but then I can't tell where it goes next. I'm guessing to a switch, then over to the BNC test port, but I'm not sure.
I spent many hours scanning Don's work and the photos to find a lot of differences that I logged in this thread: https://open-source-energy.org/?topic=2160.0. Is there any errors in the driver circuit that need to be reviewed or changed?
