"mode change"
« Reply #625, on November 11th, 2016, 09:51 PM »
If the voltageacross a dielectric material becomes too great -- that is, if the electrostatic field becomes too intense -- the material will suddenly begin to conduct current.
next understanding.
There needs to be more negative "charge"
(charge is defined by the idea of having potential difference we can call it "voltage" but that gets confusing, so we use the term "charge" just to help us understand this, like Matt was saying "electrostatic" )
the ratio 2:1 due to the fact that H2O Having two positive H charges and one negative O charge. (opposites attract) we must "match" the water charge differential. 2:1, in the cell.
Dan there is more to it than just a capacitance value. Voltage plays a big role in this. If you look at this photo of Stan's, the first level is the polarization process. You want this process to take place with around 2 volts on the primary. If you tune to resonance at 2 volts and you see no gas being produced at all then you know there is something wrong. By leaving it at resonance at 2 volts, raise the voltage from 2 volts 4,6,8,10,12 somewhere in that voltage range you should see some gas being made. What ever that voltage is that you see the gas being made let's say 6 volts. That should tell you, the turn ratio is off on the secondary, because you want it to take place at 2 volts to the primary not 6 volts. This is where everything gets tricky to adjust. In order to keep the impedance match, what you have to do is take turns off the chokes and add them to the secondary to increase the voltage. By doing this you change the inductance which will change the resonate frequency. So it's a balancing act that your shooting for. Again if the polarization process takes place at 6 volts and it's suppose to start at 2 then you've lost 4 volts in the process that you can no longer do anything with.
When gas is produced the water should be maintained in the water-gap.
The step-charge is due the chokes, but with a limit on voltage amplitude. The number of pulses are adjusted to get up the staircase (higher voltage amplitude). The WFC keep it's charge due the diode and the current is restricted at the same time to charge it.
This to me is the very culprit in understanding one of the basic fundamentals regarding a Meyer WFC.
If the WFC is to keep it's charge, to me that means that the cell walls has to be "coated" with a layer of gas as gas is a poor conductor of current. So in order to maintain this layer then more current has to flow to replenish the gas having escaped the cell walls, while more gas is being produced in the water cavity between the electrodes through the fracturing process itself, so current is very low and the fracturing process operates on voltage "only" in this case.
So it's Either that, or part of the process is to get the gas to stick to the electrode walls, preventing it from escaping, either by using voltage or electrostatics or whatever, while the fracturing process is up and running producing gas the Meyer way in the water cavity between the gas layers, which means that current through the cell is near zero while the voltage is fracturing the water in this case.
Is either of my theories anywhere near the truth here?
Otherwise what is it that I'm missing altogether?
thereby preventing and inhibiting electron-flow to pass through or arc-over capacitor water-gap
think i might have discovered something, might seem trivial but seems the circuit has been drawn incorrectly for a long time.........tricky old stan eh!
I just wanted to do the same, but I do not know how to put a picture
whether you can find and put a picture electron extraction circuit fig 1-14
yes -and absolutely the same thing is happening in WFC and people should think more logical where the electrons go from the water ie from a partially ionized HHO gas
also resonant choke -The main purpose is that choking all above and below the resonant frequency
so the main question what then is choking at resonant frequency
you're probably right for classical explanation from the book
but let me remind you on the power of resonance-
Mechanical resonance can break down any building and even entire planet
most efficient heating of metals electrical resonance
Radio TV radar EMR NEMR spectroscopy, electrical resonance again
all other electronics avoids and prevents resonance especially in power supplies
electrical generator in resonant conditions almost always burn out which directly says if L and C cancel each other how within the system we have enough energy for burnout
I do not want to mention the Tesla Stan and several other what they do with resonance
so the bottom line you really still think that resonance choking something
Yes, you are right, if you do it wrong you burn the VIC!
