Finally I'm beginning to get the whole picture here, how important it indeed is to check the interactions there are between Meyer's electronic cards as they're all working together to both keep the VIC and the WFC producing gas and also to prevent them from blowing up in the process.
I can only imagine how many hours of work you and your team have spent delving into these very inner workings of Meyer's electronics, mucho kudos for that
:thumbsup:Many thanks Ronnie, that's very unselfish and generous of you to share all this with us.
I just wanted to take this opportunity to quote the quote of all times that I've ever had the good fortune to come across,
What I've seen all along is people throwing 12 volts to the primary and trying to tune to resonance. Can you see the problem why you can't do that? Your using all the voltage you have to tune into the first level of resonance and not allowing the capacitance to change. It's just like doing the same thing at 1 volt but you've use up all the voltage before anything changed. You have to take it through the different voltage levels and tune to resonance at each level. At each level an amount of gas will be released changing the capacitance. As you take it through each level more gas will be released until you reach the last level of resonance by that time gas is in the cell and water is removed and voltage will take over and go to infinity and amp drops.
