ok guys i have been hard at it!
here we go...
this is acetal delrin and man i think i like this plastic a lot!
i thought it was not as durable but its as strong or stronger than UHMW and much better to work with... but you get what you pay for also...
hey! look at that! a real replica... lol the first 13 bobbin cavity iv ever seen replicated... Wink lol
starting with a new 13 bobbin cavity...
this is the exact using stans original drawings found here:
http://open-source-energy.org/rwg42985/russ/Injector/VIC%20Design_RWGresearch.com.pdf[attachment=1650]
[attachment=1651]
[attachment=1652]
[attachment=1653]
[attachment=1654]
ok now here is the kicker... i dont know if i was a fraction off or if the dezighn is flawed... it was mentioned that the wire would not fin in the bobbin... i know my inner outside was a fraction small and my slots were a fraction small my depth may have been off a fraction also... with that said. i think it would all fit but just barely as you can see here:
this is the 430FR wire from stans estate.
[attachment=1655]
[attachment=1656]
the first one got in a bind and i kincked the wire here and there and i was not happy but what else could i do... so the wire was just a test fit... not really usable...
here i warped it with that fiberglass tape... works well but its a bit thick.
[attachment=1657]
now. i really think i figured out how the primary winding is suppose to be... from my other bobbin tests here is what i did.
i marked out where the slots were.
[attachment=1658]
then i warped the wire right on top. one winding only. this is 22 awg.
[attachment=1659]
[attachment=1660]
then i taped that up:
[attachment=1661]
for the secondary i did have some 30 awg heavy build wire so i just used it but i do have some triple build 36 and 38 awg coming. will need to test with that next as i did see all kinds of arcing...
:) [attachment=1662]
[attachment=1663]
here it is on the same core i had from don. interestingly its really close to the drawings but its too long...
[attachment=1664]
[attachment=1665]
here it is next to the other 14 cavity bobbin cavity:
[attachment=1666]
[attachment=1667]
now. test time...
interestingly the SS 430 wire was arcing all over the place on to the outter steel lamanets... it was crazy voltages coming out...
the bad thing is that it burned off the insulation from the ss wire and i believe it shorted internally... the coating is very bad and dose not stick well to the wire so i think my kinks did it in...
:( it is else old stuff coming from the estate... will need to try the tests with the new stuff when it gets here... when ever that is...
here is some photos... i could get about 1.5" arc at the fight frequency...
[attachment=1668]
[attachment=1669]
here is a video of the test... as i was filming it stopped arcing as i believe the ss wire shorted and was socking up all the BEMF!!!
its a bit of a download or you may stream it i think... its a .MOV file
214MB file...
may need to right click and save as:
http://open-source-energy.org/rwg42985/russ/13%20cavity%20arcs%20VIC.MOVand there you have it... that was alot of work for 2 days...
:) i also have some of those connecters ordered..
:) http://octopart.com/11351-keystone-10526196blessings! let me know some thoughts!
i will make a new video today with all this and post it here also:
