If you are an ordinary oscilloscope, already grounded via outlet in the land of installationQuote from Webmug on February 21st, 2013, 09:42 AM To make it clear... "isolated ground" is not a physical connection to anywhere with a wire.Quote from ~Russ/Rwg42985 on February 21st, 2013, 09:35 AM Ray don, where is your 0 refrence ground in your test? I don't rember if you stated it in your video. This would help.Quote from Webmug on February 21st, 2013, 09:32 AM Yes! I know what you mean. My signal is AC. And so my scope shot is not exactly the same but if you connect resistance in the from of a WFC the reference isolated ground is forming unipolar signal ,this is my opinion.Quote from Ray Don on February 20th, 2013, 02:03 PM find your 0 referance ground, please
You can see the step-charging in the inductor with AC.
Don't know how the unipolar was formed (didn't see a connection diagram etc) used perm. core turns, but there where two 3 inch WFC connected in series.
Regards,
Webmug
Thanks ~Russ
Regards,
Webmug
The VIC is a electro static field generator so the probes are picking it up without physical connection. Example, if you connect scope ground probe you pulling it to 0 level :D
Regards,
Webmug
