(Found this interesting... about INERT GASES, from an unrelated topic.)
"The first one we shall present harnesses the white-hole repulsive properties of the centre of atoms. Let us now give three appropriate examples utilising these principles, starting with the latter, the antimatter reactor. For this example, any of the inert gases would be more effective than other elements. The inert gas does not react chemically with any other element. It has a stable structure of completed electron shells due to a powerful nodal force within the nucleus.
If we subject the inert gas to high pressure and temperature we can strip away the (negative) electrons surrounding the positively charged nucleus. The atoms thus become highly ionised.
If we now apply a powerful magnetic field, the nucleus of the inert atoms, consisting of protons and neutrons, is disturbed. Remember the fractal principle we have discussed in other articles in which true wholeness exists in its own right at different natural entity levels of the universe, for example, a planet, solar system, or an atom, or even its nucleus. Thus by disturbing or even removing any protons or neutrons does not remove the inner white-hole property of the nucleus. Under these conditions these centres or nodes of atoms are exposed--powerful energy is coming into our 3D. This is quite compatible with quantum physics that tells us everything is under continuous creation--this creative energy is coming into our reality to create it, through natural entities, such as atoms. This is also the source of the power of the atomic bomb--a neutron splits the nucleus, exposing the nodes of the fissile material releasing huge quantities of 'white-hole' energy. However, the magnetic field does not disturb the nucleus of the inert gases to create this dangerous mode.
This outflow of energy from the central nodes of these exposed atomic nuclei would push against any matter, giving rise to repulsion. Thus this is a potential method for creating a localised antigravitational field. This system has apparently been achieved secretly, and since we haven't heard about it publicly we can only assume it is the work of the secret government. But they have more advanced systems than this now."
