I'll tell you what,Quote from freethisone on September 30th, 2012, 02:07 PM Yup what is important is the voltage across the cap. he can fire it every time at 250 volts. perhaps a lower capacity will also work. currently 35 thousand micro farads? correct me if i am wrong. i thought thats what Russ said in the movie.
what i also think will work, 3 shots of increasing voltage. but hey if you wanna play u have to pay. Russ has all the fun..:(
cheers.
If I had the cylinder, piston, thorium electrodes, hydrogen gas, and what not,
I'd be all over this, popping my own cylinder silly.
I think I know enough to get a basic setup up and running, all that's needed
is the "hardware", the electronics is just collecting dust here......come to
think of it, I still have my spark plug tester intact, that would do the HV job.
Then I have my variac to rectify and charge the tank caps.
I also have a vacuum pump...........AAMOF, I'm not missing all that much actually :D
And away to transfer it to the cylinder.
Also do not forget the electronics are Important in an engine application. Not so much in a popper application...
