Hi John,
In a post a few pages back #1064, I implied that a electron in the field could receive enough energy to keep it in the field...This brought about electrons building up in the field where upon they (in the case of the earths field) would conduct that energy back to earth through birkeland currents as the charge potential increased...
Russ alludes to the self series resonance of a inductor building up outside the coil and the eventual charge going to earth....He says we can capture it by encasing the coil...
Your video is plastered with the electron which you was denying existed in the first place...but I can forgive you that....and states about the obsevation of a single electron flying off....I put it to you that the single electron could have been part of the current flow induced by the collective charge out there in space...
could you not see plasma as the accumulative of the charge in space reaching that energy trigger level.
Dont answer till you have seen russ's latest video...#15
and read in post 1069, the pdf 'four letters from a mathematical physicist'
Best regards...stay chilled.
If anyone had bothered to just put down the old theories and see this as I and others are seeing it, you might understand why I say there is no electron. At best it is a shell but a shell of what? That is what led me to Plasma Physics. I tried to show many examples both mechanical and electrical of the proof that all matter resides in a Plasma sheath. This sheath is also surrounded by opposite sign of Plasma. This is a well known Plasma Physics mechanic called a double layer. Whats in between those layers are balanced Plasma or a bidirectional coupling of both Plasma.
Again for you reference:
https://en.wikipedia.org/wiki/Sierpinski_triangle#/media/Fi
The red particle is very dynamic in size and charge carrying particles within it's body.
The blue particle is fixed when you compare the two side by side or balanced mode.
If you zoom the picture in you will see that the red particles point up and the blue particles point down.
The Red whole particle is full of space, hence why I call it the vehicle of charge. Even smaller red particles ride in those spaces when the blue particle is not there and the tips bang into the red bases giving it charge or enables magnetism.
The Blue whole particle is full of surface and has no space hence why it is voltage only responsive and is the structure of space itself.
A balanced particle pair either has equal amounts of red and blue as shown in the middle of the two whole particles merged together or they can become polarized and stick base to base with all sub particles base to tip.
Neutral space is the particle shown between the two particles merged. Polarized space is when they sit base to base going in one direction.
These particles are highly dynamic in movement and the shape dictates it direction when a potential or charge is present.
Of course since this is fractal based this is just a frozen picture with no other smaller particles shown. They have to have larger and smaller particles but for the mechanics that can be sidestepped for this conversation.
The truth is that we do not know if there is an electron period. Hell I don't know if these are real but this explanation is much better because you can get everything we want out of this example. I call these particles Plasma because this is what matter floats in and is able to transmit it's radiant information through space to everything else in matters environment. Plasma is the environment that matter floats in and conducts through.
All of the effects that we can see like induction and electromagnetic induction is fully explainable via this example even the electric field and magnetism, light, heat. All...
What is not explainable in the theories we have now is what is the electron floating in? How come it can act like a particle and a wave? Well my example explains that. I just don't have all of it mapped out yet. The current theories only describe the the math. We can not locate the electron, not because we haven't tried but because in this example it doesn't exist. The best picture of an electron will shock you.
https://www.youtube.com/watch?v=ofp-OHIq6Wo
