Russ,
Okay I watched your latest video, but I still haven't read your document. You expressed some interesting outside-of-the-box ideas about the short pulsing of the coil and possibly extracting more current out than you put in. I think you might be able to devise some tests for that. But for right now, let me throw some stuff at you for you to consider as you develop your understanding and formulate your strategy.
I watched the coax test clip also, the "homework" clip and it was very good just like you said.
I think you are getting some crossed signals with respect to the velocity factor in a coil and the potential for excess energy from the coil because of the internal inductive and capacitive coupling between turns, and in an attempt to get my point across I am going to use an ocean liner analogy for you.
There is an ocean liner at rest in a harbour, the engines are off. There is a worker in the bow of the ocean liner and he hits a horizontal metal beam with a sledge hammer. The horizontal beam forms part of the ribbing for the hull and it traverses the full length of the ship. There is a worker in the stern of the ship and he has a stethoscope placed on a metal beam. When the worker in the bow of the ship strikes the beam, the worker in the stern of the ship hears it with his stethoscope a few milliseconds later due to the propagation delay. Makes sense?
And of course you talked about the velocity factor for the voltage signal propagating through the coil and how it is similar to a coaxial cable and both can be modeled as transmission lines. That's fine. So when the worker strikes the beam that is just like the transmission line setup in the coil.
Now here is where I think you might be going astray. The fact that a signal can snake its way through the coil and possibly induce more capacitive and inductive coupling in the coil is not the real issue here. This is all small-signal transmission line stuff happening. But the real energy dynamics are for the full coil, and the full coil is the ocean liner. The ocean liner has to get up to speed slowly by engaging the main engines and it might take the ocean liner half an hour to get up to speed. And this is where I think you are crossing signals.
The pulse motor operates like molasses in January as the commutator makes contact for an "eternity" and the lumbering huge coil slowly builds up a magnetic field. The small-signal transmission-line-effect propagation of a signal though the coil has nothing to do with the slow brute force it takes pushing on the coil to slowly build up the magnetic field in the coil.
Now, if you think the secret for extracting extra energy from the coil has to do with the small-signal transmission line effects, that's fine. But the claim for the Newman motor is that it puts out considerable amounts of power, and the possible small-signal transmission line effects and coupling effects you are talking about are like a feeble sledge hammer tinkling on the metal rib of the ocean liner and the power to actually drive the pulse motor comes from the giant steam turbines that drive the propeller.
The feeble sledge hammer signal is very quick, sound travels much faster in steel than it does in air. But the real action is with the main engines, and they can take a long time to move that massive ocean liner.
Those two signals are very different things and I hope you are not mixing them together.
SS
Wonderfull, your now seeing that most of what I'm. saying is possibal. And your seeing wjere the RF energy is coming from.
So you are getting the hard hard to understand part down...
And yes I agree about the small inputand the magnetic feild. But you don't grasp why Newmans motors work magneticly. You can't skim his book, you must master it. This is a true statement. So, you don't need that much current to make a massave feild... This is the point.
To your ship...
Re read the 3 text slides in that video 15.
I said " If there is no Induction from the magnet"
Now re watch video 14 I posted last week. This explaines this 100%.
This induction effect IS the source of power in the second 1/2 of Newmans work... And this is what he tries to show you in his book.
Everything in Newmans system is adding. And you CAN get a current and voltage back from the coil greater than you put in. I already demonstrated this. I however haven't don't it own its own, only the proof its possible.
As I have been working on the new comutator for this to show its self on the bench.
This coil is not really the best for this due to the bad inductave coppling. So we get what we get but it gives us 100% confennce that its possible. And is nothing more than fardays law of I suction, and magent interaction with the flux from the coil.
Re read the last 3 pages of this thred, I nailed the point in more than 3 places. In fact I repeated my self 3 times to make sure everyone was clear what I was showing in video 14.
Your getting there ans soon it will click.
Greate feed back!
