Cycle,
But the quantum world and the macro world are two different things.
Two
interrelated, interconnected things. To deny this is to deny the very foundational underpinnings of, for instance, matter itself. Without the quantum vacuum, matter would not exist, as Boyer and NASA explain in my prior post.
I think you are also mixing up Larmor radiation and the fact that a moving point of charge (electron or proton) subtends a magnetic field.
Larmor radiation is the physical explanation for the emanation of a magnetic field from an accelerating point charge. It is in the form of virtual photons, which mediate the electromagnetic fundamental force. A moving point charge (the orbiting electron) undergoing rotation about the nucleus
is undergoing angular acceleration, the two requirements for Larmor radiation being a moving point charge, undergoing acceleration.
Larmor radiation refers to EM radiation radiating away from accelerating charges but from what I gather the subtended magnetic field around a moving point charge is not radiated away.
Incorrect. According to quantum mechanics, an electric field is merely a magnetic field in a static frame of reference, therefore a magnetic field is an electric field in a moving frame of reference... the quantum vacuum polarization around the nucleus is what changes that frame of reference for the emitting point charge (the orbiting electron), hence magnetism.
Rather, the magnetic field is inherent to the moving point charge.
No. There is no 'inherent' in the universe... everything has a cause. Larmor radiation and vacuum polarization is the explanation of the cause of magnetism.
However, I am not competent in QED at all so I am just skimming the surface.
There are two issues with this for me. You are talking in generic terms so why isn't this "replenishing" phenomenon being exploited everywhere today?
Because everyone has been taught that doing so violates the Laws of Thermodynamics, so not very many want to put their careers on the line by following a line of inquiry which everyone says is impossible, perhaps?
The thing is, the 2LoT is for a
closed, isolated system... any machine we build (which utilizes the EM fundamental force) is not (cannot be) a closed, isolated system due to the quantum vacuum interaction.
Quote from https://en.wikipedia.org/wiki/Second_law_of_thermodynamicsThe second law of thermodynamics states that the total entropy can never decrease over time for an isolated system, that is, a system in which neither energy nor matter can enter nor leave.
From what you are saying it is not specific to a Newman motor. Secondly, the discussion is about the energy in the LC resonator and what happens to that energy and not anything really to do with a permanent magnet.
The energy is being transferred back and forth between the coil and the permanent magnet, you cannot separate the two and look at the system from the vantage point of only the coil or only the magnet. The permanent magnet has two factors to consider, the electron kinetic energy (and hence momentum), and the macroscopic kinetic energy of the magnet itself. The coil is merely the means by which to convert that electron momentum into macroscopic kinetic energy of the magnet itself.
This is where you sit down in front of your setup with a pencil, an eraser, and some graph paper and you develop timing diagrams, described in an earlier posting. You make timing diagrams for the simple basic tests you mentioned. You annotate them explaining what the signals are and what they do and and show any interdependencies between signals. You can even add your own virtual signals for things like electrical work or energy and mechanical work or energy.... or quantum vacuum interaction.
:D
