« Reply #26, on December 10th, 2016, 09:51 PM »
ok i set the driver circuit in a sim, the only way i can get any thing to work is replace the 470 ohm resistor with a 47k ohm.   This is on the Q7 base, going to 0V
when its 470 ohm, i cant get it to do nothing, i guess that's because there is not enough current flow.
brad, try switching out that resistor.
also what value are you using for the N/A resistor on the TIP 120?
try a 47K as well. something like 470 is to low .
« Reply #34, on December 11th, 2016, 07:30 AM »
@Matt
maybe it makes more sense to make a separate board for the transistor stage - why?
if the transistor stage is able to deliver a bias for magnetic flux it can be driven by any pulse generator input / also pulse generators that are already in operation.
an alternative could be to make a pcb layout with separate transistorstage and pulse generator so that pcb can be cut to use transistor stage stand alone.
best way to me seems to be to make a 2 parts pcb connecting them with pcb connectors
https://youtu.be/QIwaSzlXgmc
« Reply #35, on December 11th, 2016, 09:56 AM »
Quote from Gunther Rattay on December 11th, 2016, 07:30 AM
Yes.  Russ and I pretty much agree on a very simple driver board.  My feeling is that it should have an optically coupled signal input and a battery connection.  The output would be the two leads to each side of the VIC primary.  All the transistors and regulators would be on the board.  Just a simple module that doesn't actually produce any pulses, just passes them through Stan's circuits as described.
With such a board, you can feed it any sort of signal you like and use this board to control the power/amplitude going to the VIC.
May take me a few days to get something sketched out and several more days to arrange a decent board layout.  If you all like what you see posted here, I'll send the files off to be manufactured.  You can PM me your drop address and I'll ship them to you when they're done.  And by heck somebody better make lots of Hydroxy gas using them, because I know when I croak, my wife will throw all the stuff I've made over the years into the dumpster.
haxar
« Reply #38, on December 11th, 2016, 10:54 AM »Last edited on December 11th, 2016, 11:01 AM
My estate should be exactly in the same state as I leave it a year later. Digitizing it would last a long time.
I guess she prematurely wanted you / it gone. You know how to use a screw driver? Hope you're able to recover some.
« Reply #43, on December 11th, 2016, 12:13 PM »
so you finely got some of your stuff back??? This would be helpfull!!!!!
Hope your doing well Ronnie. Say hello to the grand kids for me!!!!
Also. I wanted to understand that driver circuit. because I clearly remember it not working when I first put it together. So I thought I'd run it through a simulator just to make sure I understand how and what is supposed to happen and so far the simulator agrees to my findings years ago it didn't work right. So I don't know how it's supposed to work right but I'll be changing a fuel resistor values so that it at least works right. At the current state it didn't even put any pulses. Not sure if you saw the same thing.. Brad?
HMS-776
« Reply #45, on December 11th, 2016, 01:43 PM »
Quote from ~Russ on December 11th, 2016, 12:13 PM
I had the same problem....tried again to stimulate it the other day at still can't get a pulse through it.
Ronnie is there any chance you can show us what the waveform across your primary coil looks like?
« Reply #48, on December 11th, 2016, 02:32 PM »Last edited on December 11th, 2016, 02:34 PM
Quote from gpssonar on December 11th, 2016, 10:39 AM
Hey Matt, how would you like to have something like this and you was proud of it like a new born child.
And then next time you got to see it, It looked like this, Thanks to a wife that didn't even wait until I passed away to throw it out.
Probably a good thing it's you and not me.  If it were me, one of us, either her or I would not be walking this planet anymore.  Or as my ol' man would have said, "Bring a gun, because I'm going to."
The good news is, we're all going to have something like that we're proud of, "all we need is a little more time..."
