I might have got the driver circuit working correctly in multisim?
The resistor that comes from +10V to the base of Q6 will not allow the circuit to work unless it is over 1k but if it's that high disconnecting it altogether is no different. If not the Q6 transistor gets more current from the resistor off the +10V than it does from the incoming signal and then a continuous DC voltage passes through Q6.
The 470 and 1k resistors I kept the same but then changed the base resistor at the TIP120 to 4.7k.
I am getting the classic gated waveform now but no DC bias?
The only way I can get a DC bias is by adding a resistor from the primary coil +V to the base of the TIP120.
