like here look at where the ground is, this is in only a few diagrams everything else the ground is left off. :
haxar
« Reply #100, on October 25th, 2016, 09:18 PM »
Ronnie, i have a simple Question. explain how and why the diode is in there. we know we are trying to make DC not AC Correct?
Merc, if you dont know much about the phase and what it dose with C and L do read up on it, you will need to know about it, google "Power Factor" and r3ead up on it,
also read up on it here find the sections related to L C and Resonance, and Power factor.
http://open-source-energy.org/rwg42985/russ/books/Hawkings%20Electrical%20Guide%20Full%20Set%20Vol%201-10.zip
if you under stand phase shift, sorry for extra information, for others who do not know the relationship between voltage and current, do read up on it.
for for me the diode dose may have more reason than meets the eye.
Russ, i haven't seen that drawing where did it come from? It goes against everything he has said about an isolated ground. It has to be a mistake or something. I have looked at all his VIC's and none of them are grounded. So I can't comment on that one, other than he mislabeled it.
I would like to draw up something to explain the diode before I comment on it. So I can put some visual to it. I will work in it and post it.
I never thought to tune with a empty cell or..... set the offset to 2v
Ok thanks. Will do between exams
Man, am I glad everyone is starting to understand this, I thought it was going to be painful form me to explain and get everyone to believe in it.
I just want to thank Allan, Neal, Matt, Ris, Dom, Adam and Brad and others for giving me confidence to do this. Without them, I more than likely would have never made the decision to start this thread and go public with this. The last thing I wanted was make a claim I had it working and then come out looking like a fool trying to explain it. There is still plenty to explain, let's just hope and pray I still don't end up looking like a fool.
That's a good photo to share, I was going to share it later, but since you already have I will talk about it.
First: it shows that the chokes does not have to be on the same core material as the primary and secondary. You will find a few more to prove this in the Tech Brief.
Second: It shows a balance coil design which leaves you with only one variable left that you can make adjustments with. (which is the capacitors) Which he used tubes that he could slide up and down to make adjustments with along with a flat plate cell that is a variable to tune the system.
Third: The l2 choke is always an amp inhibitor until the system hits resonance them and only then will it react with the other coils.
I can't remove post here, I have no control over this thread. It's not in my bench, a moderator will have to do it for you.
will get to it... for now continue on :)
Can you tell which coils are aiding and opposing each other?
I can also see the L2 coil appears to have fewer wraps of wire. At least is looks a bit smaller in diameter to me.
