Thanks Russ, it just takes me out of the loop of control of peoples post. I want everyone to feel comfortable posting here.
What I would like to do at some point is to fill two separate balloons of equal size on with Faraday gas and Stan's Gas and light them on a video. To me that would be a better video for everyone.
I dont know about Ronnie, But I am getting real tired real fast of people bothering to see a running cell. Keep it up guys maybe you will piss Ronnie off enough to just stop helping you.
It is easy to write off the people that piss you off. But also bear in mind how easy it is to forget the ones in the crowd that try not to! I try not to. And yet if i say little or nothing at all how easy would it be to paint me with the same brush as well as the others trying to take notes and trying to not step on toes.
Merc
Merc you are different than others bro. its the ones that keep asking for Ronnie to show a video of his cell working. Can you imagine how his life would be turned upside down if he did.
When the wright brothers flew a plane, it helped that people saw them do it. Never in the entire history of the Royal Institute in London did anyone ever present a theory without showing a working principle to go with it. It's bad science and it's not the accepted way of doing things.
I'm not disputing Ronnie and his explanations of how things work but before I put a soldering iron to anything I want to see it working otherwise it's a no go for me, sorry but that is just how it is. If there is no working model then I carry on doing things my own way, if I see a working model then i'll follow the lead. I've learned over the years to take everything with a pinch of salt, that is no disrespect to anyone on here but that is how it has to be. My system is built and ready and it can either go Ronnie's way or my own way, if I see nothing in Ronnie's work that I think will help me then I'll go down my own road. Like I said, no disrespect to Ronnie but that is the way I operate and if I fail doing so then so be it.
Nav, I don't want anyone to believe in me, Believe in Stan Meyers he's already done a video for everyone. All I'm here for is to tell what he didn't. If what I have said so far doesn't help people get a working cell, then I am wasting my time. What is important is making your own video some day soon. Just keep watching this and believe.
https://www.youtube.com/watch?v=nOGAkRkCWfA
Ronnie, having read what you've said about the function of the VIC and tuning of the cell etc, can you explain how those principles fit into the below schematic for Stan's simple bifilar system. You will see that both coils lengths are the same and there is no primary, it is fed with rectified AC voltage in bursts using a gate. The voltage is 0-115vAC probably using a variac.
Can you explain to the forum the phases of the bifilar, each coils relationship to each other and their relationship to the cell and why Stan has written 'Amp inhibiting circuit (without amp influxing)'
No gas no play for me Ronnie, no disrespect to you but I got things to do my own way.
OK, I'd waited till the 24th to see what was on offer before I picked up a soldering iron and changed anything. The soldering iron stays in the stand and i'll carry on with what I was doing before the long wait until the 24th.
Second: It shows a balance coil design which leaves you with only one variable left that you can make adjustments with. (which is the capacitors) Which he used tubes that he could slide up and down to make adjustments with along with a flat plate cell that is a variable to tune the system.
That's a good photo to share, I was going to share it later, but since you already have I will talk about it.
First: it shows that the chokes does not have to be on the same core material as the primary and secondary. You will find a few more to prove this in the Tech Brief.
Third: The l2 choke is always an amp inhibitor until the system hits resonance them and only then will it react with the other coils.
Ronnie, Is that second stage (resonance) automatic when the voltage goes up to a certain level or we have to do something special?
We can clearly hear Stan saying that resonance superimposes the particle impact to the polarization process rising the yeld of gas production (New Zealand house meeting vídeo)
Good deal Nav, no disrespect taken. I don't know what to say to you. You had it all worked out other than knowing this part of it. Putting the soldering iron back up just because I'm not showing a video. Tell me before you leave, How would a video of my cell make you keep your soldering iron out? Other people that I have told this to, before I even posted it here can see how it works now, It brought out a few soldering irons out of the closets. All I can say if it brings a few out and lose one that's still a net gain.
