What does the energy (in/out) ratio look like at the moment.
so far we have proven that the brought force approach works. this was the starting place.
Is the force-distance that the popper piston delivers over unity?
right now no where close. but again this is proof of concept.
Have you experimented with pre-exciting the noble gas mixture with the
27.105 Mhz through the RF antenna prior to delivering the ignition arc?
no, this is on the back burner but is still on the list of things to do.
Does the magnetic containment field help to increase the force as well?
haven't got to those tests yet.
Have you made any new videos since January?
dec 4 update 19. papp tech
all other videos are not really related to papp tech.
From recent postings on this blog it seems that the focus has shifted more toward brute forcing the plasma reaction with lots of amps of
current from capacitors instead of finessing the plasma with magnetic fields and RF pre-excitation. Have you proven to your satisfaction that
the lower energy approaches cannot generate the plasma transition?
what is happening now is a lot of really good theory based on past testing. with this theory we can do tests that lean in to that theory to prove or diss-prove it to be accurate. one of the things I'm currently doing is working on the controlling circuit to apply short burst of energy rather than an uncontrollably amount of power going in to the popper.
This will overall lower the input energy. the "finessing the plasma with magnetic fields and RF pre-excitation" may work but possibly only with radiation " buckets" of witch we don't have. so we must find another way to help the process. so cap discharge had been found to be effective. along with other sources of input energy like magnetic fields and RF pre-excitation.
If generation of more power out than in is the goal, I would think that
lower energy approaches would be considered in preference to higher energy approaches to making plasma. Am I wrong?
this is an accurate statement. and i would say your not wrong. but the main part is the " crossover" part of the papp motor that we just don't have with the current popper setup. so this is where testing theory's and making the process better will prove us the future testing of a motor type of application where we can reach those lower level energy input stages of testing...
as of goals. here is some of the past goals we haven't gotten to yet:
http://open-source-energy.org/rwg42985/popper/POPPER%20TEST%20SHEETS%20v1.6.doc but will once the weather clears up a bit. ( 0-40 degrees F out there) i work out of a crappy center block garage "lab" and it has no heat. so i'm doing inside projects at the moment. family time and reorganizing the "basement lab" so its usable.
so as it stands everything is slowly moving forward and i hope to get back in the grove soon.
blessings. hope this explained some of whats in the works.
