now what has changed? ice age model also prides a 4 dimensional system, and also describes its function.. add that later to ice age..
i make my argument that something has changed in the wording of the following.. i answer my question, why in the past everyone who tried before me fail??
well they didnt..
Euclidean geometry
"Plane geometry" redirects here. For other uses, see Plane geometry (disambiguation).
Detail from Raphael's The School of Athens featuring a Greek mathematician – perhaps representing Euclid or Archimedes – using a compass to draw a geometric construction.
Geometry
A fragment of Euclid's "Elements" on part of the Oxyrhynchus papyri
P. Oxy. I 29, one of the Oxyrhynchus papyri, includes a fragment of Euclid's Elements.
History
Branches[hide]
Euclidean
Non-Euclidean
Analytic
Riemannian
Differential
Symplectic
Projective
Algebraic
Concepts
Features
[show]
Zero / One-dimensional[show]
Two-dimensional[show]
Three-dimensional[show]
Four / other-dimensional[show]
Geometers
by name[show]
by period[show]
v
t
e
Euclidean geometry is a mathematical system attributed to the Alexandrian Greek mathematician Euclid, which he described in his textbook on geometry: the Elements. Euclid's method consists in assuming a small set of intuitively appealing axioms, and deducing many other propositions (theorems) from these. Although many of Euclid's results had been stated by earlier mathematicians,[1] Euclid was the first to show how these propositions could fit into a comprehensive deductive and logical system.[2] The Elements begins with plane geometry, still taught in secondary school as the first axiomatic system and the first examples of formal proof. It goes on to the solid geometry of three dimensions. Much of the Elements states results of what are now called algebra and number theory, explained in geometrical language.[3]
For more than two thousand years, the adjective "Euclidean" was unnecessary because no other sort of geometry had been conceived. Euclid's axioms seemed so intuitively obvious (with the possible exception of the parallel postulate) that any theorem proved from them was deemed true in an absolute, often metaphysical, sense. Today, however, many other self-consistent non-Euclidean geometries are known, the first ones having been discovered in the early 19th century. An implication of Albert Einstein's theory of general relativity is that physical space itself is not Euclidean, and Euclidean space is a good approximation for it only where the gravitational field is weak.[4]
Euclidean geometry is an example of synthetic geometry, in that it proceeds logically from axioms to propositions without the use of coordinates. This is in contrast to analytic geometry, which uses coordinates.
Contents
1 The Elements
1.1 Axioms
1.2 Parallel postulate
2 Methods of proof
3 System of measurement and arithmetic
4 Notation and terminology
4.1 Naming of points and figures
4.2 Complementary and supplementary angles
4.3 Modern versions of Euclid's notation
5 Some important or well known results
5.1 Pons Asinorum
5.2 Congruence of triangles
5.3 Triangle Angle Sum
5.4 Pythagorean theorem
5.5 Thales' theorem
5.6 Scaling of area and volume
6 Applications
7 As a description of the structure of space
8 Later work
8.1 Archimedes and Apollonius
8.2 17th century: Descartes
8.3 18th century
8.4 19th century and non-Euclidean geometry
8.5 20th century and general relativity
9 Treatment of infinity
9.1 Infinite objects
9.2 Infinite processes
10 Logical basis
10.1 Classical logic
10.2 Modern standards of rigor
10.3 Axiomatic formulations
10.4 Constructive approaches and pedagogy
11 See also
11.1 Classical theorems
12 Notes
13 References
14 External links
The Elements
Main article: Euclid's Elements
The Elements are mainly a systematization of earlier knowledge of geometry. Its superiority over earlier treatments was rapidly recognized, with the result that there was little interest in preserving the earlier ones, and they are now nearly all lost.
There are 13 total books in the Elements:
Books I–IV and VI discuss plane geometry. Many results about plane figures are proved, e.g., If a triangle has two equal angles, then the sides subtended by the angles are equal. The Pythagorean theorem is proved.[5]
Books V and VII–X deal with number theory, with numbers treated geometrically via their representation as line segments with various lengths. Notions such as prime numbers and rational and irrational numbers are introduced. The infinitude of prime numbers is proved.
Books XI–XIII concern solid geometry. A typical result is the 1:3 ratio between the volume of a cone and a cylinder with the same height and base.
The parallel postulate: If two lines intersect a third in such a way that the sum of the inner angles on one side is less than two right angles, then the two lines inevitably must intersect each other on that side if extended far enough.
Axioms
Euclidean geometry is an axiomatic system, in which all theorems ("true statements") are derived from a small number of axioms.[6] Near the beginning of the first book of the Elements, Euclid gives five postulates (axioms) for plane geometry, stated in terms of constructions (as translated by Thomas Heath):[7]
"Let the following be postulated":
"To draw a straight line from any point to any point."
"To produce [extend] a finite straight line continuously in a straight line."
"To describe a circle with any centre and distance [radius]."
"That all right angles are equal to one another."
The parallel postulate: "That, if a straight line falling on two straight lines make the interior angles on the same side less than two right angles, the two straight lines, if produced indefinitely, meet on that side on which are the angles less than the two right angles."
Although Euclid's statement of the postulates only explicitly asserts the existence of the constructions, they are also taken to be unique.
The Elements also include the following five "common notions":
Things that are equal to the same thing are also equal to one another (Transitive property of equality).
If equals are added to equals, then the wholes are equal (Addition property of equality).
If equals are subtracted from equals, then the remainders are equal (Subtraction property of equality).
Things that coincide with one another are equal to one another (Reflexive Property).
The whole is greater than the part.
Parallel postulate
Main article: Parallel postulate
To the ancients, the parallel postulate seemed less obvious than the others. They were concerned with creating a system which was absolutely rigorous and to them it seemed as if the parallel line postulate should have been able to be proven rather than simply accepted as a fact. It is now known that such a proof is impossible.[8] Euclid himself seems to have considered it as being qualitatively different from the others, as evidenced by the organization of the Elements: the first 28 propositions he presents are those that can be proved without it.
Many alternative axioms can be formulated that have the same logical consequences as the parallel postulate. For example Playfair's axiom states:
In a plane, through a point not on a given straight line, at most one line can be drawn that never meets the given line.
A proof from Euclid's elements that, given a line segment, an equilateral triangle exists that includes the segment as one of its sides. The proof is by construction: an equilateral triangle ΑΒΓ is made by drawing circles Δ and Ε centered on the points Α and Β, and taking one intersection of the circles as the third vertex of the triangle.
Methods of proof
Euclidean Geometry is constructive. Postulates 1, 2, 3, and 5 assert the existence and uniqueness of certain geometric figures, and these assertions are of a constructive nature: that is, we are not only told that certain things exist, but are also given methods for creating them with no more than a compass and an unmarked straightedge.[9] In this sense, Euclidean geometry is more concrete than many modern axiomatic systems such as set theory, which often assert the existence of objects without saying how to construct them, or even assert the existence of objects that cannot be constructed within the theory.[10] Strictly speaking, the lines on paper are models of the objects defined within the formal system, rather than instances of those objects. For example a Euclidean straight line has no width, but any real drawn line will. Though nearly all modern mathematicians consider nonconstructive methods just as sound as constructive ones, Euclid's constructive proofs often supplanted fallacious nonconstructive ones—e.g., some of the Pythagoreans' proofs that involved irrational numbers, which usually required a statement such as "Find the greatest common measure of ..."[11]
Euclid often used proof by contradiction. Euclidean geometry also allows the method of superposition, in which a figure is transferred to another point in space. For example, proposition I.4, side-angle-side congruence of triangles, is proved by moving one of the two triangles so that one of its sides coincides with the other triangle's equal side, and then proving that the other sides coincide as well. Some modern treatments add a sixth postulate, the rigidity of the triangle, which can be used as an alternative to superposition.[12]
Euclidean geometry has two fundamental types of measurements: angle and distance. The angle scale is absolute, and Euclid uses the right angle as his basic unit, so that, e.g., a 45-degree angle would be referred to as half of a right angle. The distance scale is relative; one arbitrarily picks a line segment with a certain nonzero length as the unit, and other distances are expressed in relation to it. Addition of distances is represented by a construction in which one line segment is copied onto the end of another line segment to extend its length, and similarly for subtraction.
Measurements of area and volume are derived from distances. For example, a rectangle with a width of 3 and a length of 4 has an area that represents the product, 12. Because this geometrical interpretation of multiplication was limited to three dimensions, there was no direct way of interpreting the product of four or more numbers, and Euclid avoided such products, although they are implied, e.g., in the proof of book IX, proposition 20.
An example of congruence. The two figures on the left are congruent, while the third is similar to them. The last figure is neither. Note that congruences alter some properties, such as location and orientation, but leave others unchanged, like distance and angles. The latter sort of properties are called invariants and studying them is the essence of geometry.
Euclid refers to a pair of lines, or a pair of planar or solid figures, as "equal" (ἴσος) if their lengths, areas, or volumes are equal, and similarly for angles. The stronger term "congruent" refers to the idea that an entire figure is the same size and shape as another figure. Alternatively, two figures are congruent if one can be moved on top of the other so that it matches up with it exactly. (Flipping it over is allowed.) Thus, for example, a 2x6 rectangle and a 3x4 rectangle are equal but not congruent, and the letter R is congruent to its mirror image. Figures that would be congruent except for their differing sizes are referred to as similar. Corresponding angles in a pair of similar shapes are congruent and corresponding sides are in proportion to each other.
Points are customarily named using capital letters of the alphabet. Other figures, such as lines, triangles, or circles, are named by listing a sufficient number of points to pick them out unambiguously from the relevant figure, e.g., triangle ABC would typically be a triangle with vertices at points A, B, and C.
Angles whose sum is a right angle are called complementary. Complementary angles are formed when a ray shares the same vertex and is pointed in a direction that is in between the two original rays that form the right angle. The number of rays in between the two original rays is infinite.
Angles whose sum is a straight angle are supplementary. Supplementary angles are formed when a ray shares the same vertex and is pointed in a direction that is in between the two original rays that form the straight angle (180 degree angle). The number of rays in between the two original rays is infinite.
In modern terminology, angles would normally be measured in degrees or radians.
Modern school textbooks often define separate figures called lines (infinite), rays (semi-infinite), and line segments (of finite length). Euclid, rather than discussing a ray as an object that extends to infinity in one direction, would normally use locutions such as "if the line is extended to a sufficient length," although he occasionally referred to "infinite lines." A "line" in Euclid could be either straight or curved, and he used the more specific term "straight line" when necessary.
