Building it is the easy part. Just wrap your coil with coaxial cable.
Understanding what is happing with this arrangement is a little more difficult. First, one has to understand that certain fields can be shielded and others cannot. With a coax cable, nothing is shielded on the outside conductor, but the inner conductor is a different story. That difference is what makes such a device asymmetrical.
In physics
Asymmetry arises in physics in a number of different realms.
Thermodynamics
The original non-statistical formulation of thermodynamics was asymmetrical in time: it claimed that the entropy in a closed system can only increase with time. This was derived from the Second Law (any of the two, Clausius' or Lord Kelvin's statement can be used since they are equivalent) and using the Clausius' Theorem (see Kerson Huang ISBN 978-0471815181). The later theory of statistical mechanics, however, is symmetric in time. Although it states that a system significantly below maximum entropy is very likely to evolve towards higher entropy, it also states that such a system is very likely to have evolved from higher entropy.
Particle physics
Symmetry is one of the most powerful tools in particle physics, because it has become evident that practically all laws of nature originate in symmetries. Violations of symmetry therefore present theoretical and experimental puzzles that lead to a deeper understanding of nature. Asymmetries in experimental measurements also provide powerful handles that are often relatively free from background or systematic uncertainties.
Parity violation
Main article: parity (physics)
Until the 1950s, it was believed that fundamental physics was left-right symmetric; i.e., that interactions were invariant under parity. Although parity is conserved in electromagnetism, strong interactions and gravity, it turns out to be violated in weak interactions. The Standard Model incorporates parity violation by expressing the weak interaction as a chiral gauge interaction. Only the left-handed components of particles and right-handed components of antiparticles participate in weak interactions in the Standard Model. A consequence of parity violation in particle physics is that neutrinos have only been observed as left-handed particles (and antineutrinos as right-handed particles).
In 1956-1957 Chien-Shiung Wu, E. Ambler, R. W. Hayward, D. D. Hoppes, and R. P. Hudson found a clear violation of parity conservation in the beta decay of cobalt-60.[citation needed] Simultaneously, R. L. Garwin, Leon Lederman, and R. Weinrich modified an existing cyclotron experiment and immediately verified parity violation.[citation needed]
CP violation
Main article: CP-violation
After the discovery of the violation of parity in 1956-57, it was believed that the combined symmetry of parity (P) and simultaneous charge conjugation (C), called CP, was preserved. For example, CP transforms a left-handed neutrino into a right-handed antineutrino. In 1964, however, James Cronin and Val Fitch provided clear evidence that CP symmetry was also violated in an experiment with neutral kaons.
CP violation is one of the necessary conditions for the generation of a baryon asymmetry in the universe.
Combining the CP symmetry with simultaneous time reversal (T) produces a combined symmetry called CPT symmetry. CPT symmetry must be preserved in any Lorentz invariant local quantum field theory with a Hermitian Hamiltonian. As of 2006, no violations of CPT symmetry have been observed.
Baryon asymmetry of the universe
Main article: baryogenesis
The baryons (i.e., the protons and neutrons and the atoms that they comprise) observed in the universe are overwhelmingly matter as opposed to anti-matter. This asymmetry is called the baryon asymmetry of the universe.
Isospin violation
Isospin is the symmetry transformation of the weak interactions. The concept was first introduced by Werner Heisenberg in nuclear physics based on the observations that the masses of the neutron and the proton are almost identical and that the strength of the strong interaction between any pair of nucleons is the same, independent of whether they are protons or neutrons. This symmetry arises at a more fundamental level as a symmetry between up-type and down-type quarks. Isospin symmetry in the strong interactions can be considered as a subset of a larger flavor symmetry group, in which the strong interactions are invariant under interchange of different types of quarks. Including the strange quark in this scheme gives rise to the Eightfold Way scheme for classifying mesons and baryons.
Isospin is violated by the fact that the masses of the up and down quarks are different, as well as by their different electric charges. Because this violation is only a small effect in most processes that involve the strong interactions, isospin symmetry remains a useful calculational tool, and its violation introduces corrections to the isospin-symmetric results.
In collider experiments
Because the weak interactions violate parity, collider processes that can involve the weak interactions typically exhibit asymmetries in the distributions of the final-state particles. These asymmetries are typically sensitive to the difference in the interaction between particles and antiparticles, or between left-handed and right-handed particles. They can thus be used as a sensitive measurement of differences in interaction strength and/or to distinguish a small asymmetric signal from a large but symmetric background.
A forward-backward asymmetry is defined as AFB=(NF-NB)/(NF+NB), where NF is the number of events in which some particular final-state particle is moving "forward" with respect to some chosen direction (e.g., a final-state electron moving in the same direction as the initial-state electron beam in electron-positron collisions), while NB is the number of events with the final-state particle moving "backward". Forward-backward asymmetries were used by the LEP experiments to measure the difference in the interaction strength of the Z boson between left-handed and right-handed fermions, which provides a precision measurement of the weak mixing angle.
A left-right asymmetry is defined as ALR=(NL-NR)/(NL+NR), where NL is the number of events in which some initial- or final-state particle is left-polarized, while NR is the corresponding number of right-polarized events. Left-right asymmetries in Z boson production and decay were measured at the Stanford Linear Collider using the event rates obtained with left-polarized versus right-polarized initial electron beams. Left-right asymmetries can also be defined as asymmetries in the polarization of final-state particles whose polarizations can be measured; e.g., tau leptons.
A charge asymmetry or particle-antiparticle asymmetry is defined in a similar way. This type of asymmetry has been used to constrain the parton distribution functions of protons at the Tevatron from events in which a produced W boson decays to a charged lepton. The asymmetry between positively and negatively charged leptons as a function of the direction of the W boson relative to the proton beam provides information on the relative distributions of up and down quarks in the proton. Particle-antiparticle asymmetries are also used to extract measurements of CP violation from B meson and anti-B meson production at the BaBar and Belle experiments.
the figure 8 is asymmetric physics
Thermodynamics
Particle physics
Parity violation
CP violation
Isospin violation
in a manner of speaking, the inner winding is a coil, the outer is a plate. the battery is the terminal, the positive is the ground.
the stout wire is fat and has little resistance, the fine wire is not. also may be wound on inner and outer cores.
super conductor, large mass. so many ways to do this..
