https://www.youtube.com/watch?v=A5BSQknc2BI
very few have seen the ice caps melt;; see these amazing screen captures by freethisone
https://www.youtube.com/watch?v=-kYILVMBunc:s
https://www.youtube.com/watch?v=7AUljj2XTSI
oh boy look what i got here, i have a nasa distance, and i have a date. the object was over 300 million miles away when i captured it on a web cam.. add some math, calculate speed....:D
OH BOY, look what else i have, 3 objects, and the comet looks like two objects.. yup yup confirmation at last, absolute proof of these objects. ill find u a Nasa- photo that call one object mars, but mysteriously spits into two objects.. confirmed. the 2 objects at the edges are the twins... called Venus, or mercury over the last 3 years. just wait till you see these images again.. i will dissect, and explain every aspect of observations clearly on the data presented shortly... in due time..
if you are curious about what i had said look for ffreethisone on youtube for all the amazing photos of these periodic objects..
my estimated period of orbit is 2013+750 years...
:shy:https://www.youtube.com/watch?v=hj1idKXAiCk
star with a tail.. u cant blow it up cause of its heavy matter, hmm
so you have that..:sleepy::sleepy:
the doomsday machine... the bow shock..
https://www.youtube.com/watch?v=KJ8uO0U_3ic
um so you have a small amount of truthful info..
this leads to the creation of a force field. hmm so u have that also. Tesla states in a book the objects, or particles that hit his craft will instantaneously become the reverse charge, and reflect.
i suggest looking at all the star trek episodes, there are many references made to man, and what the elite had thought about that subject..
so if it is a star made up of neutron star material it is heavy, and will make up for the missing mass from the universe. (dark matter, energy) if its 3 miles across, and has a 45 thousand mile wide bow shock that is the radius of planet Jupiter. who is to say eye sun comet is not the legendary second sun itself?. unless the second object is much bigger. in that case, i say holy cow.....this will discharge as a laden jar in metal conductors. sun planets moons, asteroids. there s a tension in both equal and opposite directions. i cut the string. swoop they fly apart.
the negative gravity work, or force will be in the opposite direction. this is what science is all about, observing plume waving as Maxwell has stated. being dragged by the heels of this tension.. In the poem a problem in dynamics by Maxwell himself. a marvelous interpretative of a chain on a smooth horizontal plane. As the chariot will cause our sun to do negative work, and move to equilibrium. that will bring the sun closer to us over time.
in the end they dieing star expels its last emp leading to an inc readable bow shock, as the finally on the doomsday episode.leads me too believe the sun will treat this object in the same manner, and never seeing it pull around the sun itself, because it will be repelled. negative charges of same polarity. repel now compare with the true star. see second movie..
confining increase in flux finally.
stated my observation. his induction coils are a step ahead of Rodin.
reason... who will be the first too wind a secondary on top of a Rodin. like Tesla has?
who will be the first to do it with a pancake, or a star ship or on a 6 foot iron core?
with the bifillar or any number of secondary, or primary windings.
i will tell you what to build. and i hope you will see the beauty of it. It is essentially the lag time, and the ability to add a capacitor in the form of a plate in series, to pass a strong current.
a kapangie coil is a Tesla coil.
would you like to see
coil one. my idea, but hey here it is.
first a Rodin, with its primary of fine wire over the core. next these gaps in the coil itself will be filled in with?
the secondary made of thicker iron wire, and spaced to fill in the void, and to wrap around the primary.
Ill bring you up to speed on the helix coils that are mentioned by Tesla when i have time.
you may think wow can i wind the secondary of thicker wire on the primary essentially following Marcos work, and in the opposite direction add the secondary.
either way you will need two coils of each to make experiments. one set of fine wire warped on a Rodin core or ferrite core, or a iron wire core. or air core.
as the primary, and another set as the secondary first.Big GrinBig GrinBig Grin
:heart:there is one other interesting improvement that can be made on a Rodin coil.Quote from freethisone on October 7th, 2013, 06:54 PM stated my observation. his induction coils are a step ahead of Rodin.
that is to wrap on one core the primary of fine wire, and the secondary in the opposite direction a second coil, and core. this will be your out put side. this will bring the entire vortex into play. see picture. concept.
that would make an asymmetrical magnetic field. you could even solder thicker gauge wire to the fine gauge wire, and take your time to make it continuous coil, from core one, to core two, and at each turn the addition of the secondary, including the primary wire soldered together to create the continual vortex described..
Russ could you make a 3-D print of this coil, or simulate it for me?
i could even phase shift the secondary coil by winding it off set.. cheers.
any one want to help out and do some tests. essentially it will perform as an hour glass with a fluid dynamic like magnetic generating effect. That is step one.
test on step one, plus, step two.
When it is completed a new coil will be place in the generating field to do work. lines of wire wrapped horizontally from the center vortex. so as to have a twirling about the field, and the cutting of magnetic lines of coil warped in said manner. cutting at 90 degree angles of mag force lines. so as to see at least a 45 degree cutting of force lines in both directions of said coil, due to its asymmetrically produced dynamic effect.
i could introduce inside any Rodin vortex a coil wound as a helix coil, with its out puts meeting at the bottom. perhaps a capacitor, and then a ground on one side.Quote from freethisone on October 12th, 2013, 01:18 AM :heart:there is one other interesting improvement that can be made on a Rodin coil.Quote from freethisone on October 7th, 2013, 06:54 PM stated my observation. his induction coils are a step ahead of Rodin.
i could twirl the coil about in said field.?:huh::huh:
add pictures, improved helix design at each quarter turn is rotated. add picture,:(
to get a similar effect is to take a thicker gauge insulated wire, and pound out one surface to perform all together as the primary, and secondary wire. you may see there is a tendency to produce a flat greater area surface to act as thicker gauge wire in a setup that uses both fine, and fat wires.
one other experiment to try is to wind a Tesla coil inductor as the shaft. or kapange type inductor or a six foot long inductor iron core. outlined in a patent improvement on induction coil.
iron wire is best. a primary, of fine wire , and a secondary of greater gauge wire overlapping the primary coil. you can essentially charge boost caps all day long in seconds.. sounds sweet.. like green energy..
because the vortex is a rotatory magnetic field the inductor type shaft will not need to spin.
zero point = motionless generator. cheers..:D
https://www.youtube.com/watch?v=6fBIwMP0fjo
"Extreme Weather in USA on Friday, 04 October, 2013 at 14:44 (02:44 PM) UTC."
Time to address what is self evident. solar flares are high but flux is to low to be accurate.
therefore i go out on a limb. there was a 7.8 quake followed by a 6.8
i consider this precursor, based only on information and with reason taken from what was learned. in the three years under observation, and about external net force precession.
we have angular momentum changes and induction. aurora, and volcanic eruption. large quakes. this last set may be a step to the next trigger that starts the countdown. sometimes you get one set of precursor, others times i have seen two. so a 25 day prediction or less is made for great quake, or a few 7.0 or better before the next great quake. this looks like it will trigger early. if after 25 days has past, and no great quake, another prediction is issued within 45 day there after.
If then, I am considering there will be one more set of precursor quakes before specific results. That will lead to axis shift.
so you may indeed see one more set of strong quakes within a short time of 7.0 or greater . before a issue of 45 day to signal great quake #5.
but it must still be considered the 7.8 to hit Pakistan was of 8.0 or larger magnitude.
peace.:D
"Description of from early warning
Strong storms are moving into the Midwest, dumping heavy snow in South Dakota, spawning a tornado in Nebraska and threatening dangerous thunderstorms from Oklahoma to Wisconsin. A foot of snow had fallen by Friday morning in western South Dakota's Black Hills thanks to a storm slowly moving in from Colorado and Wyoming. National Weather Service meteorologist John Chamberlain says the fall storm is one of the most intense to hit the area in a long time. No travel is being advised along some western South Dakota roads, and some schools canceled classes. As much as 30 inches of snow could fall in the area. Large hail and powerful winds were forecast to hit northwest Oklahoma later Friday, while storms were forecast from there into Wisconsin into Saturday. "
/watch?v=iE0tHDkscuE pause at 1min 20 sec.
these two object captured in the reflection?
