I was studying the power board as I started to build it have couple of questions/ comments.
Was there a reason Stan did not just use a 7810 in instead of the 317T and SCR? possibly due to age of components
or amp rating at that moment in time we do not know if he ran from mains also with this power supply
Stan's power card has a fail over capability build in. It starts on the side (right) with fuse and if fuse fails it can be switched to second side (left) by using the on/off switch on the board (front panel).
YEs we thought same and made 4 ways for fail safe on matrix 2 hard traces and 2 jumps
the extra power points there are for if for some reason we blow up 1 or 2 set of traces 1 or 2 side of power board
we can revert and jump for the extra i put them the only for back up. some thing that may prove to be very handy if
it is you only fuel source and you need to re route power on the fly. .
if any changes needed let me know
Now my other question/comment. The VIC matrix board will only support this if there are jumpers from the top half terminal screws on the VIC Matrix board to lower half terminal screws as there are no traces for this function on Matrix board.
Yes this Board is a Swiss army knife it was created to enable people to see and use the cards
we managed to preserve through many peoples hands and efforts , it was and is designed as
the engineering test bench just as Stan Wanted so we keep that general theme and fought to
go a bit over board with giving people space and options to jump things around
if needed , as if we advance 1 or more board we may find a reason to have extra power jumped around
color screen, sensors or new section to any one board etc
The flip side of this is there is no12 V input power to the side of the board with the fuse.
Again if jumpers where in place this would not be a problem.
In my testing I by passed all this by providing 12, 10 and 5v from an external source,
I did find I needed to connect to lower set of screw terminals as they are the ones that go to safety card.
The both shunts on the board have an output line to 37 pin connector and to unlabeled terminal screws.
again not needed as vic has its own power in it is a extra redundancy
Other side of shunt is connected to 12V input.
Expect it was intend to be current sensor but they are currently not hooked up.
mostly the matrix has a lot more than needed we did that intentionally as we have new systems that could if needed run from it
for example if we have a modern pdm power distribution control and safety prior to main power into matrix
we could run a ecu or Arduino touch panel in replace of resistor knobs and run them with software,
goal was to plumb the Meyer work and enable it to be modernized or at very least understood and connected to modern things in a step process , with out this being done people has zero chance of doing what we are doing together now
Yes it could be very much simplified we could delete power card safety card , but some times we find things that meyers did for a reason so we wanted to keep the things close as possible to his culture and planned design flow he had in buggy so we have a chance to discover why when how and preserve the legacy for re discovery .
Ultimately it is a Engineering model and test bench ,
it is good to rebuild safety card and power card so it cements the visions that were left by Stan, some times we look at these things 1000's of time before we realize why he did it in the way he did.
Note also the Matrix pcb was sized to fit in the same size box as the 8xa/9xa box, yes it could be tiny smaller etc but we design edit for big large font kid bench top type replications ,
miniaturization and modernizing can be done from these engineering models . lucky we have the time to put in place the step stones for people most in history of Meyers try jumping ahead to fast using digital and other things and can never see how things work. Everything is easy when you have the example to improve on but with out it we can see for 20years people could not connect the dots to create the matrix so it is important to keep the general theme so kids people or other can start at a higher less stressful level from day 1 .
