Dan made some more progress. Used 317 devices that are complete (all cap and pot on small board) to provide 10V and 5V to VIC Matrix. Combined with Power Supply supplying 12V I now have the inputs I need to continue testing. I Installed K8 to test it. First noticed no digital input on M. Fixed this by putting a jumper on screw terminals for K11 Jumper from G from K2 to M1,M2 on the screw terminals. On my test system I just used output directly from K2. The jumpers do the same thing.
Did not get desired results. Went to check using my trouble shooting steps from K8 write up. I needed to know where test points I used match the PCB layout so used traces from K8 above. I found 3 problems with the layout. All three transistor have problems. If you want to match Stan's circuit the following changes to labeling should be made. The circuit traces appear to be correct.
Q2 should be Q1 a 2N3906 that faces down PNP (power into emitter)
Q1 should be Q2 a 2N3904 that face left (2N2222 should also work) NPN (ground into emitter)
Q3 should be MPSA20 that faces down PNP (power into emitter)
NOTE: all the collectors and emitters are on the wrong sides.
I will make changes on my board and continue testing.
I will make changes on my board and retest.
