ok ,
So some questions and Notes so people see what is occurring , Ver 1
on the Version 1 Gas Card from Schematic which we are error testing for placement on matrix main board for testing and use to effect k2k3 and vic. as cell pressure changes ( this could be a on off but more likely a linear scale)
and whilst doing so provides the option for progression of understanding of the features and options. to than progress
with stans/ronnies ver 2 and les banki's ver 3
Version 1 made from schematic Current work focus
1 Ver 1 Is this a simply on off. output ? to stop production once pressure reached
2 Ver 1 does it have a linear rise on this ? to scale voltage up? ( similar les banki ) ver 3 ) pic attached
to raise lower voltage and on off , ( remember stan said it never turns off 100%)
3 did he simply replicate the on off? or does it have a linear signal to matrix?
Version 2 replicated from estate photos
1 You Mention Static fill this is where i see it mentioned this card version 2 does than mean version 2 is filling water and doing gas pressure ? if so we have made a better card on matrix call auto start auto fill.
so we may only need the gas control or at least understand it if on off or linear control. in version 2
2 did he simply replicate the on off? or does it have a linear signal to matrix?
Version 3 made and adapted to matrix db 37 by Les Banki /Daniel
1 Picture attached
2 This card is purely linear to control scaled power to cell so not meyer design but adapted and shown as a progression knowledge point.
This Note is important as we have drawn each card with matching db 37 in out to match the matric main board to allow learning testing and advancement. So to achieve a working replication and detail notes for advancing or simplifying by have install 3 card which can be swapped use which will eventually all work and may equal 1 final card which incorporates all the features show across all three, out of which i can see if there is a static water fill, than that can be omitted.
