Capacitors arrive today so I finished installing them on K8 attached picture. I have made 2 changes I used 2N3904 and 2N3906 for Q2 and Q3 as I had them. They are what I used on by test board. Rather than take apart test system I am also make new front panel for each board. I have all the front panel parts for this one. Still need to make the front panel so I can mount the parts and make the wires. It is nice that for this board all the front panel wires can go to new connections to left of the board. I plan to use screw connectors there. For my initial testing I will just use screw connections on break out connector.
While I would like to test on VIC Matrix board I am still waiting for the 37 pin sub-d connectors for that board. So I will do initial testing with a break connector as that is how I am currently testing K2 board. This way I know it works before installing on VIC Board. Nice thing about these connectors is I do not have couple pins.
Also all you need for a card extender for the VIC Matrix and board is a standard 37 pin straight through cable I purchase one but easy to make with ribbon cable and a couple of connectors just needs to straight through.
