« on August 6th, 2019, 06:14 PM »Last edited on August 4th, 2020, 09:21 PM
I Open this Thread  After a Discussion with Tony
We are all working on this Board At Present all Assistance to Replicate it  and Trace this board out is welcomed
This Thread  is Focused on
Particularly ONLY the GMS
FIRST DISCUSSION
Not just a VIC but a Board Similar to a Vic  but wired
to the Gas Processor CELL correctly as a Gas Processor
From Tony Quinn
This is the Gas Processor Circuit.
This is  the part that breaks down the molecules in air..
Yes it breaks apart all of the constituents of air..
Basically it is a large ozone generator.As it is, UV light discharge that breaks the molecules apart.It has magnetic coils at either end.These coils take advantage of the now magnetic gases by repelling them back and forth inside the processor chamber to achieve more particle collisions and yet more breakdowns occur
.Now with all of the intake gasses broken apart for almost no cost..They now move by a positive charged extraction screen..
This causes a flow of electrons that are converted in to heat..Now the output of this processor is the key to water fuel...If this electron deficient gas is mixed with the gasses from your cell output and EGR you have way more potent fuel,more energy released before water reformation.
Or if diffuse through your cell it will up the gas output by x18 plus..
So if you want to get the water fuel. You need to get one of these..The system is a Cell, Gas Processor and EGR.
.If you don't have the full system you will never move towards making water fuel for your car...
Re: The Gas Processor GMS Board Replication
« Reply #2, on September 4th, 2019, 05:37 AM »Last edited on September 18th, 2019, 09:11 PM
Stanley A Meyer GMS
Analogue Voltage Board
Paired on the Digital Control means board for Digital Accelerator
« Reply #5, on September 16th, 2019, 09:03 AM »Last edited on September 16th, 2019, 09:05 AM
Stanley A Meyer Digital Accelerator Circuit Board
  Part of the GMS unit  in Water Fueled Dune Buggy
GERBER
« Reply #7, on September 17th, 2019, 08:16 AM »Last edited on September 18th, 2019, 09:13 PM
Never Stop Stanley A Meyer Water Fuel  Injector Circuit
GERBER
Stan had 4 of these boards  for 4 cylinder VW 1600 Engine
for a
6 cylinder you will need  6 boards
8 cylinder you will need  8 boards
10 cylinder you will need  10 boards
12 cylinder you will need 12 boards
16 cylinder you will need 16 boards
18 cylinder you will need 18 boards
« Reply #8, on September 18th, 2019, 01:27 AM »
                Stanley A Meyer Regulated Power Supply from Water fueled buggy GMS  Gas Management unit
GERBER
« Reply #10, on September 18th, 2019, 07:29 PM »Last edited on September 18th, 2019, 07:32 PM
Stanley A Meyer Digital Control Means Circuit GMS PCB
Gerbers
« Reply #12, on September 18th, 2019, 07:38 PM »Last edited on September 18th, 2019, 09:38 PM
PLEASE LOOK CLOSE
Missing Card Need Drawing up and posting here gerbers
1 ) Air gate % Card LED solenoid position control       fig13-air-gate1, pics attached
2 ) Exhaust Gate % Card LED solenoid position    fig12-exhaust-gate,,15,15b attached
3 ) Air gate % tune Card    18,19,19b pics attached
4 ) Exhaust Gate % tune Card 16,17,17b pics attached
5 ) Speed Limit Module Tachometer fig16, 21, 21b pics attached in Process
6 ) Safety Control Card      22, 23, 23b pics attached
« Reply #14, on September 18th, 2019, 11:27 PM »Last edited on September 18th, 2019, 11:43 PM
Part of the board  connect  resonant interlock
need to show
distributor wiring for  twin boards
wiring for the air gate  /exhaust gate and  safety card
speed limit card
and extension card
« Reply #16, on September 22nd, 2019, 04:31 AM »Last edited on September 23rd, 2019, 06:03 AM
We are working on the harder cards now trying to work out connections on the speed control taco at this time
all comment and work to assist welcomed
Chips
1)
S+B8830
LM3914N
The LM3914 is a monolithic integrated circuit that. functions including “staging” control can be.
senses analog voltage levels and drives 10 LEDs, performed.
https://html.alldatasheet.com/html-pdf/524103/TI1/LM3914N-1/118/2/LM3914N-1.html
2)
ECG 74121  IC MULTIVIBRATOR MONOSTABLE
P213 P8640
3) LM741Cn
Op Amps amplifier Single Operational. ... LM741Cn Datasheet. ... Operational amplifier with high slew rate, low voltage, and rail-to-rail output.
« Reply #19, on September 23rd, 2019, 05:54 AM »Last edited on September 23rd, 2019, 05:58 AM
next alarm card,
we need  work on bill of materials for each card
« Reply #21, on September 23rd, 2019, 06:11 AM »
these type of switch are common and used in electric vehicles can connect to Stanley Meyers safety card on ring pull or other spot
« Reply #23, on September 25th, 2019, 07:40 AM »Last edited on September 25th, 2019, 05:17 PM
Next is the Exhaust Gate cards or egr % control
 there are 2 cards
this is first one air gate is similar
chips
1)
ECG941M
P312
274 845
2) LM391N
S+88830
3) not sure?  any one
« Reply #24, on September 25th, 2019, 05:17 PM »Last edited on September 25th, 2019, 11:06 PM
Wiring total Units
Those who have skills on this topic join in
the pictures can be zoomed into  and we can  show wiring from the  actual card pictures  at top
so we get this completed
