Apoc4lypse
« Reply #1501, on March 17th, 2018, 01:27 PM »
Be careful you don't do something that shorts the coil somehow... that would suck, a lot of wire there... cool stuff though.
Piero
« Reply #1502, on March 17th, 2018, 02:22 PM »Last edited on April 5th, 2018, 02:48 AM
I suppose I will know with bench tests but hear is a theory idea.
What is the optimal efficiency? Nearly all manufacturers of electric motors rate the efficiency at a particular level that is the maximum efficiency by in house standard test means.
That is the cornerstone of volt to amp to ohm ratios.
So if we define volts as potential if would be a hypothesis to consider that load amps resistance is realized potential.
A standard equilateral triangle is 1 volt 1 amp 1 ohm
Why using ohm ?
I prefer 1V1A1S as you told
and better 1V1S for potential
and 1V1S1A for the work we extract
can we discuss of that on one of your video lectures ? thx
Then volts high amps low intuitively means hypothetically that there is available potential still to transform in the circuit.
Classical EM relations as told by official science are shorted to four equations relations are not helpful.
The problem is how much additional load can be transferred to amps without the collapse of the magnetic field
but all of these need test to the specific dynamic electro mechanical configuration
--> B = μ.n.i(t)
so B is B(t)
Knowing that:
--> W = 1/2( ε.E2+μB2 )
and what we get is transitoire energy field energy in E ,
Can you test Newman experiment as a motor - to generate coulombs flux I
- Charge the coil
- Pulse the coil to activate the B field
- Do it such that the B field of magnet and B field of coil cancel each other
it is testing as a generator Newman machine without the magnet
talisman
« Reply #1503, on March 18th, 2018, 11:45 AM »Last edited on March 18th, 2018, 11:51 AM
Best 'generators' are at 98%, 2% as heat. The 98% using the Lenz effect to drag current
at those optimal speeds. These are for the motor alone.
In a motor generator I have seen videos where the motor and the generator are given the same calculation
with the mistake repeated where the resistance is assumed to be constant as a given parameter:
P=I^2R
Science Online motors and generators.
At the 5 minute mark the video educator uses this formula as a proof to debunk efforts at
motor generator technology.
I know that the resistance changes to speed and load and the premise is false.
He also discounts any possibility with simple looping implying there is no such thing as
a lenzless generator or a cycle recapture of waveform, parasitics etcetera (all the things
we work with in our effort); to him it's all a closed system with no recapture of energy..
Not exactly true in our pov: if a circuit is open to vacuum, we could load ad infinitum, electrons would flow.
but the Classical elct relations are not helpful.
that is to say the potential must increase in volts for levels higher ad infitum.
You have the idea of the standard triangle. It was to illustrate that the three sides change depending
on the volts amp and resistance ratio in a motor generator at various rpm and load. The triangle
changes if you freeze frame data points in time (like frames in a film for example). So the resistance
being constant being assumed in all motor generators is bunk.
talisman
« Reply #1504, on March 18th, 2018, 12:47 PM »Last edited on March 18th, 2018, 12:52 PM
Bearden says that the resistance creates electrons . If we short a circuit with a potential, electrons flow throug it.
hardware circuits especially if you talk spark gap.
My thinking is:
Electrons are charged particle moving in a particular direction relative to an object.
Protons are moving but also are charged particles it the direction opposite.
Neutrons are the perfect math not charged state in other words static (electricity)
not moving in ether direction there is no difference in potential charge or time relation
to the circuit or mechanism under study.
This would imply a load brings inertia with some of the flow in the circuit as a hypothetical theory
if the math and definitions are unambiguous.
onepower
« Reply #1505, on March 18th, 2018, 05:10 PM »Last edited on March 18th, 2018, 05:35 PM
It makes perfect sense that the critic would use the most primitive example of a motor/generator to explain away the most advanced concepts they obviously do not understand. Not unlike saying my yard is flat .... therefore all yards must be flat and the Earth as well. It is a classic logical fallacy devoid of any sense of reason in my opinion.
My thinking is that I should concentrate more on my own creative solutions to any given problem and less on what others think. At the end of the day the winner is the person that makes something work not the person who does nothing and claims it cannot work.
I like those "people are awesome" youtube video's... these people are a shining example of everything a critic could never be.
That's the motor our buddy Er wants, based on the motors he has already built. He has identified it to be "as close to perfect" possible. The only exception is to center the coil on the axis like most window motors. He suggested if one wanted to push really high voltages, build a bucket for the rotor and submerge the windings in oil.
I've been inspired by your work Russ, my daughters science project has me calculating windings... purchased 5lbs of 20awg and put a 2magnet wheel IN it... scope is very interesting. I'm mostly looking at this from the perspective you brought up about the current being in the same direction of input... I am using the inverted SSG ckt with my neg-2-neg mod to capitalize on that... very interesting stuff here. Keep up the good work.
Newman Motor
again, been out. but just trying to focuses.
minoly, yes its interesting.
here's one for you,
https://www.youtube.com/watch?v=6wmtoTCGDhI
Piero, thanks for taking the time to dive in to that.
It seems that with out the "boost" of momentum in to a flywheel to slam in to the next cycle... its quite "normal" as in the induced is less with more drag, and its more with over rotation. as it should be. so if we are going slow, I can drag it down more and draw more current from the battery, but producing more torque.
more testing to but the video i just posted is quite nice to watch... its in the right direction.
on time in that video is about ~160-170 degrees. no short, more to do...
here's one for you,
onepower
« Reply #1508, on March 19th, 2018, 09:38 PM »
Looks like its coming along, keep up the good work.
talisman
« Reply #1509, on March 20th, 2018, 04:05 PM »Last edited on March 20th, 2018, 04:34 PM
Here is where the regular theory gets wacky. Showing negative amp and positive.
The question being: Is the average reflecting the total power?
Unconventional generator experimenters the last two years have pointed to the possibility that
electronic metering devices do not always accurately reflect the power for various reasons.
This possibly could be one of the reasons:
There are two ways to see the math:
If there are negative amps and positive volts there is minus power or power literally being sucked out math wise.
So minus 2 amp plus three amp is one amp.
Is the negative amp the absence of power?
My bench says no not exactly a negative amp has power by analog gages the flow is opposite.
A remaining question then is: Is the negative power being used by the motor generator?
the devices do not accurately reflect the power for various reasons. This possibly could be one of the
reasons:
torque output ( work done) , average power (consumption, if there is any) = efficiency.
It seems that the Boost this thing gets right at the start *Could produce all negtive current the rest of the cycle. as described by Hastings.
also note, if the power is switched fast ( bad brush contact) then the result is even further enhanced. although i haven't seen/tested this just yet. but it is from the result of others..
I have been thinking a lot about how the fast pulses could be adding in the system. but haven't had time to test anything yet.
PeakPositive
« Reply #1511, on March 20th, 2018, 09:08 PM »
Russ does the new commentator have the same timing as the old one ?
Setup is looking more and more interesting.
"on time in that video is about ~160-170 degrees. no short, more to do... "
Really need to go slightly less on time I think...
« Reply #1513, on March 21st, 2018, 12:11 AM »Last edited on March 21st, 2018, 12:14 AM
Side note,
With the coil conected to the siggnal genarator...
I can rotate the magnet in the coil...
5V @ 70uA = 350uW ( micro watt).
Yes with 350 uW I can rotate the magnet lol
Pulling against gravity.
Oh man I was laughing becuse it was messing up my test lol.
https://www.youtube.com/watch?v=zyRviYzdXdk
In this update video I demonstrate how the battery resistance plays a major roll in how this system works. Even tho the battery is supplying the catalyst for the result we are seeing, the battery is also creating a "short" that is holding the magnet from going faster than it could. The "torque" I'm talking about in this video is not that great. you can however tell a big difference from the 100V to the 860V even tho the same 2ma is going through the coil when i'm holding it back. However because the more battery's we add, the less resistance across the coil, the less drag the "short" has on the magnet. so there is a balance between the induction, the battery resistance and the "free spin" rotation it has. Don't forget we are playing with a "conventional closed circuit" here.
haxar
« Reply #1515, on March 21st, 2018, 06:12 PM »Last edited on March 21st, 2018, 06:55 PM
L.M.D. is open-circuit.
The Tesla Hairpin Circuit is actually an open-circuit. It uses a cap on each end of the stout bar.
« Reply #1516, on March 21st, 2018, 06:26 PM »
A discharged capacitor has what for resistance?
A dielectric is an integral part of a resistor. So therefore, what is a resistor exactly?
Hint, it's more than just Ohm's Law.
haxar
« Reply #1517, on March 21st, 2018, 06:46 PM »Last edited on March 21st, 2018, 06:52 PM
A cap has no resistance at the leads.
No bridge.
Same as a water cap.
No bridge.
Cycle
« Reply #1519, on March 21st, 2018, 07:36 PM »Last edited on March 21st, 2018, 08:04 PM by Cycle
So essentially a low-resistance battery would 'outrun' the rotational rate of the rotor, allowing the battery to continue pumping voltage into the coil and accelerating the rotor, whereas a high-resistance battery has a voltage dip which allows the induced momentum of the rotor (after the first 15 - 20 degrees of rotation) to induce current in the same direction as the applied current. Is that correct?
If so, could you set up a constant-current supply which mimics the batteries? The voltage would be high at open-circuit, it'd dip down just as the batteries do when the circuit is closed, and current would remain at a set maximum. The constant-current supply would allow you to experiment and tweak the initial voltage and maximum current such that you can maximize the performance of the JWN replication.
Cycle
« Reply #1520, on March 21st, 2018, 07:56 PM »Last edited on March 21st, 2018, 08:18 PM by Cycle
No bridge.
Electrical resistance is defined as a measure of the difficulty with which (in a typical circuit, electrons, but not necessarily so for all circuits, since current flow can be electrons, protons or ions) flow in a conductor.
A capacitor resists current flow successively more as it charges and energy is stored in the electric field of the dielectric between the capacitor plates.
Remember, as much charge flows into the capacitor as flows out (think of it like a fluid-filled sphere with a flexible membrane bisecting the interior, and a pipe on each side, to put it to a hydraulic analogy... pump fluid in one side and fluid must flow out the other side until membrane tension is great enough to equal the applied pressure, whereupon flow ceases), so a capacitor can be classified as a conductor.
So in effect, a capacitor is a combination of an electrostatic storage device and a variable resistor (the variance dependent upon the field polarization of the dielectric).
« Reply #1521, on March 21st, 2018, 08:08 PM »Last edited on March 21st, 2018, 08:17 PM
A discharged cap has (effectively) no resistance. A charged capacitor, however, is another matter.
Resistance is the key to this device, or should I say impedance.
Is kicking our ass. We need to flip things around so that as resistance goes down, voltage AND current goes up. We need conductance, not resistance.
Cycle
« Reply #1522, on March 21st, 2018, 08:21 PM »Last edited on March 21st, 2018, 08:25 PM by Cycle
A resistor is a device that _________________.
And that's exactly what a capacitor does as it charges (that is the mechanism by which, after all, current flow decreases as the cap charges, speaking strictly on a quantum physics level). The mechanism for its doing so is different than that of a typical resistor (field polarization vs. heat emission due to electron collision), but the effect is the same.
« Reply #1523, on March 21st, 2018, 08:24 PM »Last edited on March 21st, 2018, 08:38 PM
Displacement current does not release heat, but conduction current does. So a resistor is doing something in the dielectric that causes conduction current. It's as if a resistor is actually a very leaky capacitor.
Cycle
« Reply #1524, on March 21st, 2018, 08:28 PM »Last edited on March 21st, 2018, 09:10 PM by Cycle
Now you've got it... except that the equation for capacitor stored energy is:
1/2 Q deltaV
So 1/2 of the applied energy goes to heat. Displacement current (as in charging a capacitor) does release heat.
That's why just dumping straight cap-to-cap, you'll always see at least 1/2 of your energy disappear.
Interestingly, an inductor and diode changes this relationship... the inductor 'spin-up' time changes the loss-rate of the capacitor (if you charge a cap from a voltage-following source, you'll see far less loss), and its conversion of kinetic energy (magnetic momentum) into potential energy (voltage) as it spins down allows more charge into the receiving cap.
Ideally, your inductor 'spin-up' time would exactly equal 2/3 the charge time of the receiving cap (for the applied voltage)... that's how you get the nearest to 100% energy transfer (with equally sized caps).
In fact, in certain circumstances, you can utilize the kinetic energy of the magnetic field momentum in the inductor to create a 'vacuum' upstream... with a large enough receiving cap, this gives you >100% energy transfer.
That's the operating principle for the circuit I've posted about... it's only been run on a circuit simulator to date, though, so the real world may prove a bit more difficult to get it to work.
1/2 Q deltaV
