There are a lot of options for vacuum tubes.
Currently, using relays we are limited to the switching time of the relay. In fact in my testing so far the turn off and turn on time change. as the spring tension versus the magnet field pulling the contact over is different.
The on time is about 1.7ms for my relays. and the off time is about 8ms.
so i'm limited to about 10 ms cycle time. i can get faster using resonance of the relay bounce and " bounce" the contacts back and forth to make it faster. but i'm stuck with that frequency.
also dont forget, I'm using banks of relays to do the trick. Using many smaller contacts over space to emanate the waist spark . the relays are faster than the spark over Manny contacts and then i can get that full spark in to the cap. actually the hard part is the the "short" contact. because the voltage is so high when trying to short that it will spark before it makes. more relays are needed i guess to do the trick.
also, for some notes here on a slightly different subject:
The SFR is indeed close to 90 degrees out of phase. ( current and voltage) as expected.
This brings up some interesting points.
if the current is "slamming to one side" then what happens to the voltage. theses 2 components are much diffrent when a cap is added. they ac differently.
you see, with no added caps, There is no real effect on the rotor, ( no/all most no lenz effect at all from my testing) but with a cap, there is added lenz effect. That current is now slowed heading to the end of the wire with caps added.
so adding caps slows down the resonant frequency, but SRF and resonance with caps is totally different in the way the system reacts to that change.
Just some notes for everyone to think about and also to think about what i was saying here:
http://open-source-energy.org/?topic=3128.msg48431#msg48431Extracting current with out CEMF OR INDUCTION. ( also ohms law not applied to the 45K ohms from my testing. but more proof is needed. but see my post in the link above to see why i say that's it even possible)
using the magnet to "push" this one way or another is a real effect that is normally not used with such motor / generator systems that I'm aware of.
I got a lot of the stagnant testing done but i will be doing more. then some dynamic testing will began.
