"induced in the same direction as the applied"
first off, let me say that this project is now a "secondary" project. what do i mean by that? well i have to pay the bills and that requires other tasks to get done first. I'm just posting this thought so you can see why i haven't gotten to much done lately as well as posting on the forums.
so what I'm saying is that I'm doing my best, but forgive me for the lack of posting and communication here. it might be like this in the future, however i will never stop. and ill do what i can as we all here are doing something bigger than our self's, and the outcome is greater than our self's. so... for me its one day at a time. for as long as i have another day....
Please note that the below is my thoughts currently on what i saw in only a few tests. I need a lot more testing to answer some of theses questions, that will come in the near future. so take my thoughts "with a grain of salt" everything in this post is subject to change..
ok, so... here is some of my thoughts after testing the 2" magnet inside the coil. ( for 5 min of testing...)
If you leave the coil open, you can make voltages that are off the charts. just spinning it by hand, ( my guess is 30,000V or more with less than 1000 RPM.)
Its not necessarily the voltage that interests me. But rather the good flux coupling with the magnet. This is why i did it. but ill take the voltage
;)so with that said. let us look at the induction. I asked a question a while back, it was to see what happens when the induction current is greater than the applied. And dose the magnetic field flip in the coil when this happens. ( as current is now going in the wrong direction. )
This will give us more clues to that answer. but its also a different question now.
It is, is there any torque on the shaft when the magnet is inducing and "adding" to the current from the battery? or do they cancel out?
so let me explain what i saw. with the coil shorted. and the magnet "spinning" ( more like doing nothing because i cant hardly spin it at all due to it acting like a solid chunk of copper) the magnet can be spin but had huge resistance ( i need to measure the current in the coil still) it felt like it was almost locked.
so it acts like i thought it would. However I thought it would act like a magnet in a solid pipe, as in the magnet facing parall with the coil and doped down the tube. However that's not the case. it only has resistance when the N/S are 90 degrees from the coil. ( or anywhere not parall with the coil, but strongest at 90 degrees)
so what that said, spinning it with any responsible RPM is impossible with any low resistance on the coil. The 9V battery's i have have a resistance of about ~91 ohms.
so with 11 battery's Its about ~1K ohms of resistance. so... even tho the magnet wants to spin, it will spin only as fast as the resistance on the coil will let it... ( calculation could be done here differently but I'm using the resistance as a guide to the limiting RPM via how many battery i have across the coil)
is this making sense ?
Basically the battery is the load here... even tho the battery is also the source of input...
So with 11 battery's, (110V) the current across the 45Kohm coil is about 2.5ma From calculation ( once reached the charged steady state, with no induction)
so with 60 battery's ( 575V) we should see about 12.7ma of current once reached the steady state. And according to the scope shot after the coil is allowed to charge its right at that value. so all numbers match.
with that said, there are reasons why we want high voltage, because it has a greater battery resistance. allowing the rotor to spin faster. in newsman teaching... more voltage the better... only need just enough current to align the partials...
now something to note, the more
voltage you apply the the more
torque you generate. current... ha...?!?!
all common sense right? nothing new here?
now lets get to the interesting part,
the magnet is trying to go forward but its limited to the RPM that the resistance will let it go. ( battery as a load here)
Induction in the same direction as the applied. it seems it cant "out run" its self at this RPM, (In my case I was just applying power by hand and seeing what happens. )
so the rotor spins, and it will stop when the magnetic fields are aligned.
here's the kicker, as its aligning ( spinning) its inducing a current in the coil, so this current is almost completely canceling the applied current from the battery.
however the magnet still tries to align its self to the coils field.
as this is happening, the input power is almost nothing. let us say .5ma of current, the rest is generated by the magnet its self.
however because the magnet cant go faster than the applied current ( as a steady pace) it instead is regulated... ( by the resistance in this case closing the circuit on the battery and creating resistance.)
so so that's great... now what.
wells let us ask a question. If the current from the battery is almost "nall'd" by the magnets induction current. Is there any torque on the shaft? if so how much? and dose it equate to the current consumed by the battery? or is the torque more powerful then the consumption?
so think about it. There is almost no current coming from the battery, instead its from the magnet. So there for if we try slow down the magnet ( load the shaft) we should need more current from the battery right?
well yes, however it all depends on how much we are inducing... If we are inducing 100ma of current, and we are applying a maximum of 12.7ma... Then it will take about 87.3ma worth of "torque" on the output shaft to show any increase in current draw from the battery... ???
now lets look at my quick results. I need better ways to measure this stuff but for now it " feels" like this is true (literally, i can feel it trying to hold the magnet back and watching the current i can feel the torque, and more voltage = I cant hold it back and the belt will jump teeth. however the resistance goes up. and the induced current changes. There is a balance ( tuning) here between the induced, the resistance of the battery, the induced from the magnet, ect )
so as the magnet is trying to speed up, I'm trying to hold it back, when this happens it oscillates in my scope shot. that and its doing that a little bit on its own. its hard with only 2 poles.
However the real question is ... is there torque? well from that quick test YES, and it feels like a lot more than the current I'm reading on the scope. however I'm comparing this to the torque i was getting on the magnet when it was outside the coil. so its hard to tell what real power it is making.
Voltage is indeed pure catalyst in this configuration... and only enough current is needed to get alignment... the induction seems to take care of the rest. Or so it seems... more to do...
on a side note, This catalyst is why you can just " loop it". Although in this testing we are still consuming a tiny bit from the battery's. I cant switch it in sync to cut it off before it makes it it past the induction state of rotation.
You can see it start the normal "charge curve" after this induction state.
Piero, can you try your best using your good math skills and your knowing of maxwell's equations / other to explain how its possible to generate great torque with almost no current, but rather Just voltage. using the induction current in your calculation i guess? I'm guessing to do this you will need more info on things, so if so, ask what measurements to take.
also please see the attachments as they might help in your understanding of what Hastings did. see here:
http://open-source-energy.org/?topic=3128.msg48353#msg48353Things i will do soon,
1. measure the current across a resister = to the battery resistance to check the induction current / voltage.
2. Attempt to get real torque measurements to confirm the thoughts in this post. micro pony break?
3. Run this as a motor / generator. (although it seems unless i have way to get Past TDC on its own inertia I'm not going to be able to keep it running like this. ( need 2 magnets / coils at 90 degrees from each other. ) or i might try adding a fly wheel.
lets remember this quote:
"If the torque and induction constants are equal,the motor is nearly one hundred percent
efficient. If the torque constant exceeds the induction constant, the efficiency* exceeds
100%.
[*Note: the PRODUCTION efficiency can exceed 100%; the CONVERSION efficiency
cannot exceed 100%]"
