OK i went back and edited my original post so lets start again here:
http://open-source-energy.org/?topic=3128.msg48424#msg48424so like i said. the current in this case is like water in a rubber pipe. one end has a vac and one end has more pressure. and depending on when you short this coil the result is different when measuring current flowing in the shorted coil.
now we really need to think more on the lines of whats mechanically happening with gyro particles and there spin and there deflections, but for this right now will stick with water hammer type effects.
dont forget, this effect is amplified VIA induction, and magnetism. if it was a straight wire the effects would not be the same. at least not in this amplitude. so as i described in my video i posted. the induction is very important.
in fact, when you have a charged coil and you pull both ends off the source... you can generate that "vacuum" in one side and "pressure" on the other side. a potential deference. when measured across the coil ends.
see the purple trace. This is the effect measured at the ends of the coil.
so let me ask you this, if you then reconnect the supply while the void is there... can you draw more water in the pipe faster then if it was not under a vacuum?
aka, we
should be able to pull more "power" in to the coil at a faster rate than we could at any other time... ( more then what the battery can supply normally? also more than what the induction will allow)
let me show you, here in this shot we see that there is about >1ma of current going in to the coil. (blue trace) ( ignore the green here, the settings are off for proper measurements)
so that's the max we can get to go because the resistance and because the supply.
so you would ask your self, can we get more current to go though that coil from the battery?
well... yes we can. how? using that void...
here in this shot we can see that the "vacuum" is generated and because of the high difference in potential there is an arc.
this arc is a negative resistance so it acts like a short once its formed and allows max current to flow through the gap.
so when the battery is connected to this via the spark the current surges. way more than it could normally.
Now you can see it happens over and over and over for as long as the potential difference is high enough to jump the gap. Think of this like your breaks slipping then grabbing then slipping then grabbing. "jumping" ( the blue trace is not quite fast enough to see this. but the green current resistor on the coil is faster with more details) and the battery also dips a lot showing power being drawn.
here is the same from further away:
the battery is also dipping very far so it is real power going in to the coil.
this is very interesting because it showed that there is a "vacuum" there and its slowing a lot more power to be drawn in to the system that otherwise could be because of the induction effect and the resistance drop dot apply the same here.
so the next question is to ask. can we to this in reverse? can we extract power this way?
to answer that we need to also look at what happens when we short the coil when ts ringing. if it s ringing "up" dose current flow one way, and of going "down" is it the other way? this would indicate that the current is going back and forth. (well it would at lest show that the difference in potential will flow in the either one direction o the other once connected " shorted" )
In the fallowing the green is measuring current in the "loop" of the coil. so when we short it we can see the direction of current flow.
so here we short the coil when the potential is going "up" ( green spike going down)
so here we short the coil when the potential is going "down" ( green spike going up)
here you can see that i short it a lot faster and you can see that discharge curve. some going in one direction, and others going in the revere! ( see the top small zoomed part of the image)
now the question is, is this current flowing because of the potential difference or because of the current flow? I would suggest that the potential difference IS "pressure" from the current trying to go in that direction. so the magnetic field has no where to go and nothing stopping it. so it is "ringing"back and forth. current and voltage. It even seems to be to the ends of the wire.
so what that said. can we extract power faster than the time charge/discharge time constant using this spark discharge method? id say yes.
also, now add in what happens when you have induction from the magnet while all theses things are going on... you can " push" this charge around as Hastings was saying.
more to do...
