I had time to think about the gas "lattice" today:
https://www.youtube.com/watch?v=ndyeWrcvITA
What do ya think?
What do ya think?
Yes ill get some pics up as soon as i got something to show.Quote from Rwg42985 on June 3rd, 2011, 04:21 PM Good update.Quote from phil on June 3rd, 2011, 03:35 PM Im waiting on delivery of parts, the only truly non magnetic pump i found was a drill powered pump for £8, bakolite body with a rubber impeller 1000 lpm, you connect it to a drill or motor or whatever you want i did have my eye on a swimming pool pump as that has all plastic impeller but it was like £80 and i didnt want to pay out on that and only use the impeller and be left with a dirty great electric motor that i wasnt going to use, ordered a big lump of 25mm diameter x 200mm long soft iron rod to make the cores out of. Gonig to pick up a lathe/milling machine combo hopefully next week sometime.
Once im done im gonna do a test run with water, just to check for leaks and see how the pump runs, then blow the core out with compressed air and go for ferro fluid.
Ive wound one primary on a PTFE tape reel once i get the iron core done ill have a play with the primaries.
I have toyed with the idea of getting a couple of bad ass N52 ring magnets made up with a 10mm hole up the middle to provide the magnetic field and try just a pump/permenent magnet arrangement, forget about the pulsing. Might get DC output from that.
Can you post a photo of the core you are going to make? After some testing the core may need separate cores... Spaced slightly apart. And I'm building a copper EPG to spec of stans... I have this felling that Ferro fluid was used.
What was your calculation of the amount of Ferro fluid?
Thanks for the update.
i need 2 cores for the mech EPG, one either side of the pump. The centres of the plumbers tape spools are 25mm hole. The soft iron rod i ordered is 25mm Diameter. Just gonna cut two lengths 16mm thick and drill a 10mm hole in the centre to fit the copper pipe thru. Got my speaker knobs to hold the things in place at the ready, just waiting on the core.
My calculation for the amount of fluid was.
Copper OD 10mm. Wall thickness 0.7mm.
Copper ID is 10mm-0.7mm-0.7mm = 8.6mm ID.
Therefor radius is 4.3mm.
PI x 4.3 x 4.3 = 58 mm2.
Take the 58mm2 this is the cross sectional area of the tube ID and multiply it by the length of the spiral plus any additonal fill point etc. Will give you the volume of the pipe. (If im using a pump there will be a bit extra to fill the pump body).
I think my spiral is about 4.7m long. Your pipe should have about the same 58mm2 crosssection as mine. Just insert your tube length in the calculation.
I convert to centimeters here so i get milliltres in the answer.
0.58 cm2 x (tube length in centimetres) 470cm = 272.8 cm3 or 272.8 ml.
A 500 ml bottle would nearly fill 2 18 inch EPGs. Cost about £200 so thats what $350? or you can brew your own from PCB etchant ferric chloride, household ammonia and oleic acid. They are all cheap. I posted a link here showing a process where it was done on a small scale and it wasnt that great yield. I'd be guesiing you'd need to knock it up in a barrel the get the 300-400 ml you may need. Didnt wanna do it in my back yard in case the neighbours thought i was cookin meth, ha ha. It would be cheaper to make the ferrofluid yourself but it looked quite labour intensive...lots of stirring.
When faced with spending all weekend stirring a barrel of goo givng off fumes, i choose to do some overtime and buy a bottle.
If you ever get you hands on 500ml bottle of ferro fluid i think you should give one of your rodins a bath before you pour it in the EPG, always wondered how the fields would look around one of those things. Would we see the vortex?
I do however see one problem with ferro fluid. Ive been watching vids of electromagnets and FF. The magnets seem to be much bigger than the EPGs coils and they only move the FF a couple of inches at best. I cant see how the magnetic field from those two coils(mech EPG) makes it thru 4.7m of copper pipe filled with FF. Im sitting here with 2 permenant magnets and its more like 4.7.cm they start to attract.
But then ive only been watching videos. Maybe its just the surface tension of the oil looking like its a weak reaction and those iron particles are goin nuts under the surface.
Still i want to get as much kick out of my primaries as possible. Am i right in thinking short sharp high voltage pulses into the primaries will do this? Big magnetic reaction in the coil? Maybe off a spark gap, i got some little tranformers out of plasma globes somewhere. Or a litle NST.
Top job with the knightrider coils. Just what i wanted to see happen too. See if someone can donate you some david hasselhoff leather trousers. ha ha
What do ya think?
Nate, love that your thinking on this level…Quote from firepinto on June 6th, 2011, 08:42 PM I had time to think about the gas "lattice" today:
What do ya think?
well, the magnets left and right of the center magnet will attract like you think, but the magnets below and above will be the opposite as there trying to align N – S so if you had ring magnets and you had 4 of them, and they made a square pattern, there would be 2 facing one way and 2 facing the other…
so you will have a zig zag pattern with your flux lines… yes?
Then if you turned them I think they would lock up… like fighting each other…
Now if you had just one big magnet ring with one row of magnets then this would work just fine!
One other thing is that the gas lattice is not the direction you are describing, it’s the opposite.
See there is suppose to be a magnet on the entrance of the EPG to align the gas the correct direction…
So if you had a gas with a bunch of tinny magnets you would have a pattern like this…
(from stans video)
Also states that the argon in an insulator.???
Thanks, ~Russ
(from stans video)
Thanks, ~Russ
What do ya think?
If you spin the drive magnet thru the centre on a shaft would it cause all the other magnets to flip like dominos? Or i wonder if the combined stregth of all the other magnets would overpower it.? Either way i can seee there still being a lenz drag on those magnets if you started putting coils around them.Quote from firepinto on June 6th, 2011, 08:42 PM I had time to think about the gas "lattice" today:
What do ya think?
I just had a little play with 3 magnets in a row. they did want to flip one after another, but it felt like the drive magnets rotating force was being split between the magnets.
Try tying a string thru a few magnets and weigh the bottos down so they can pivot without sticking together and give it a try.
I have been reading up more about helium. There are some interesting facts about helium-3 that I want to gather up and post
I just drew up this half baked idea I've been having for winding EPG coils. I don't know how much help it would be especially in the areas where the spool will bump into the pulse coil tubes. I drew it on paint.NET, but I also saved it as a .bmp and attached both.
Ill see if I can explain how it would work. lol The blue and part would be in two halves, with slots allowing adjustment for the 4 screws that attach the gray clamping bars. I would say the gray bars are clamped down on the EPG copper pipes first, then attach the blue "bearing" halves. The red part either needs to be in halves, or have a slot cut in to allow it to be slipped around the copper pipes. I didn't draw anything for that. :-P The 3 screws with washers are what hold the "bearing" together. They should be tightened just enough to let the washers spin. Washers are on both sides, and are what hold the red part centered with the blue part. The screws should be more evenly spaced, its a quick sketch! lol The large bolt with the wing nut is what holds the wire spool, and gives it tension. Once it is together you just rotate the red part around to wind the coil on the EPG copper. An adjustable wire guide could possibly be added to keep the coil winding neat.
It might be more trouble to make than it is to just wind by hand. But I thought i would pass it on. :-)
I haven't been able to get matt in here so i am posting some of his stuff from facebook
youtube channel is: "mattimber"
Matt Imber
"My EEC is a first prototype. I really need to wind the coils using the same wire, and I'd like to have the coil cores (spools) made of a Faramagnetic material or even Metglas. I've started a new EEC coil assembly using a bifilar coil assembly directly wound onto the copper tubing. I still need to assemble the PWM & Toroid to my power supply and see if this improves the efficiency. The EEC theoretically acts as a gas deionizer, making the HHO more parahydrogen and para-oxygen - provding more energy. I thought of adding LEDs in between each coil to help direct the flow of electrons in one direction."
Matt Imber
"The coil of tubing with the coils in series around the tubing is what I envision the Electron Extraction circuit was that the late Stanley Meyer had working in his patents. I need to place diodes (LEDs) in betwen the coils (100 coils with ~100 turns = ~1000 turns = ~100 volts, which is theoretically induced by the hydrated electrons inside the tubing, in which HHO gas is run through aft a bubbler or directly from a wet cell electrolyzer design or dry cell. The following video shows a recent replication of an EEC, but this is a later version called the Hydrogen Gun" Stan Meyer invented: https://www.youtube.com/watch?v=jXdDZk6ubII&feature=related. It's basically a water plasma (HHO Gas) deionizer. It siphons off the "hydrated electrons" from the charged gas cluster mixture of O2 and H2, with the extra 4 electrons per water molocule. Theoretically, the coils are induced spontaneously, provided the coils all rotate the same direction, and the diodes in series between the coils are also all facing the smae direction. The resulting effect is that the 100 diodes on the EEC assembly would glow like a Christmas tree and burn off the free electrons as the JJO gas passes thru the tubing. This deionizes the HHO gas and makes it more powerful, resulting in "Para-Hydrogen" (as opposed to "Ortho-Hydrogen" ) according to Moray King"
Matt Imber
"I've not yet assembled the EEC. I've been too busy with my other projects, which include my garden, but I'm getting close. I have wound the 6 inch toroid coild that I learned to do from reading the Bob Boyce D9 Pusle Width Modulator (which I also have ready to assemble). I would like to avoid using saintless steel altogether, though and would like to collaborate with a local guy to use my EEC in combination with his brass emitters used for bioelectric therapy - similar to what John Kanzius was doing. I don't want catalysts like KOH or pot ash lye, etc. I also don't want hexavelant chromium in the water from the stainless steel. I want to the most bang for the buck."
Matt Imber
"This part of my Electron Extraction Circuit (EEC from Stan Meyer's Patents) I plan to install on the HHO electrolyzer (Google: "Joe Miracle Cell" for the video). The copper tubing will have HHO gas (oxyhydrogen gas) flowing thru it along with water condensate, and also trillions of hydrated electrons from the broken covalent bonds from the water dissassociation. The 100 small coils, are in series encircling the copper tubing of HHO, will serve as the large electron extraction coil on the EEC. This coil will be in parallel with a winding on the toroidal transfermer choke coil for the DC pulse width modulator (Bob Boyce D9 design or similar). A blocking dioade also helps get the flow going in the EEC."
Love the HHO gun, Here is some supporting information for the electron spin components responsibility for the subsequent photon EMF.
click here for
full lecture
https://www.youtube.com/watch?v=5M6uI9uZARA
Because of Rayleigh scattering there is a five to one chance of this scattering with UV light over red.
so the higher UV range will scatter, or add a pressure to move more diploles then with IR alone. So there is more then one thing going on here.
Rayleigh scattering (named after the British physicist Lord Rayleigh) is the elastic scattering of light or other electromagnetic radiation by particles much smaller than the wavelength of the light, which may be individual atoms or molecules. It can occur when light travels through transparent solids and liquids, but is most prominently seen in gases. Rayleigh scattering is a function of the electric polarizability of the particles.
Good find on that pump mate, I was hunting around for that for ages. I had to settle for a swimming pool pump in the end, chose it because all the parts are non magnetic or plastic. Ive actually nearly finished mine just the electronics and ferrofluid now, ive had to wait for a spare motor to crop up at work. youve actuallly done me a big favour in confirming that red pump is for liquid and not gas. Thanks. I dont really expect its goin to let me live off the grid but i do expect to see some sort of effect, at least to prove the concept. Maybe ill have it up and running in 3-4 weeks if you can wait that long, or by all means have a crack yourself, just bear in mind you could be adapting it for gas one day.
