I have a few question about the Version 1 LED board operation.
I assume that we want board to operate in Bar Graph Mode. If this is correct the mode select switch is wired incorrectly as pin 9 should be connected to PIN 3 (chip's plus supply voltage) according to Data sheet. Wiring on board shows it connected to pin 1 on next chip in series which is correct for DOT MODE.
Does the chip pull output low when TPS voltage rises?
I believe I do have the latest Gerber File from above.
Note: This article also talks about additional wiring to cascade chips and use a common reference voltage range
https://learn.sparkfun.com/tutorials/dotbar-display-driver-hookup-guide/all
Earl
Earl
