That I did not check K8 It does change something on VIC output you can see it 3 pictures above that showed coil output above, below 50% at 50% and above 50% it could be caused by the voltage level change I just did not look at it that way but this is one of the effects of changing voltage level. I just did not try to measure it. Can see the VIC 50% one in last picture as well. With other settings I had set if you drop below 50 the signal goes away which what happens when you lower voltage drops below minimum value. When you raise voltage the AM signal fills in more. I have seen this happen in my testing when I was changing the offset voltage.
To some extend you can also see the signal fill in when you change the gain on VIC.
What I do not know is how much you can get it to change. My guess is it will go up some but not all the way to 11/12 volts. Will check both K8 and VIC and report results. I believe in pictures of VIC I had scope set to display DC offset. What is miss leading in picture is the Digital pulse is always 12V.
Earl
Earl
