my 1 to 3 has no bearing on the image 123
sonnet
« Reply #350, on November 18th, 2017, 12:46 PM »
some questions are:
is he still reversing battery polarity every half revolution?
the caps eat the spark but is he still shorting the coil?
(seems to me like the best way to get a good pulse)
if you don't short the coil(s) how do you get a significant pulse?
240 revolutions per minute is 4 revolutions per second. We will attempt to get the current almost all the way through the motor coil in 1/2 revolution. So we have 4 RPS which is 250 milliseconds. Cutting that in half is 125 milliseconds.
Light travels 300,000 meters per second. With an approximate velocity factor of the wire insulation set to 80%, the propagation speed will be reduced to 240,000 meters per second. Let's shorten things by 1/8th (125 milliseconds) to get a distance of 30,000 meters, 30 kilometers.
Dude, that's a lot of wire. I'm not even sure one can buy spools of wire longer than 1000 meters; you would need to spice 30 1000 meter spools together and that's a single strand. Think about 20 strands or more. Starts to look a lot like a nightmare of wire.
I think I would go for much more accurate balance and attempt to run the motor at 2400 RPM. That would at least cut the total wire length down by a factor of 10. Three kilometers of wire almost starts to sound doable.
ha heres one for you...
"electricity is a non compressible fluid."
I propose what Newman states. "hydraulic effect."
my view on it though.
Current is a non compressible fluid ( held with in the copper its self) you could call them the atoms them self's. current never gets out of the battery.
Voltage IS compressible... like a gas. you could call this the electrons... They can be compressed... and they DO move out of the battery. via pressure. ( more negative, more the electron density and the higher the pressure also.) (more positive the less the density and more "negative" pressure. )
this makes A LOT more scene.
so the current cant do anything but align the atoms in the copper.. so only a little is needed. The smaller the wire the less is needed.
But the voltage can "push" out the field like pressure in a rubber pipe. so more pressure the more expansion.
this also work's better with the idea of the water hammer effect...
yeah go ahead... tell me my flaws now... it sure feels SPOT ON...
more thoughts that seem not quite spot on...
so its possible to compress the voltage as a pressure wave in free space. But the current can not be so. but the atoms can be aligned in the copper like a wave propagation. This makes current and voltage "the speed of light" in free space ( vacuum) ? but with in solids it can be slowed down.
Its also possible pressurize a pipe Instantly ( voltage) But if the pipe was closed at one end then you only get the current ( flow) to go in one end and it would seem that the current went in but did not make it through the loop...
So the same as a pump pumping gas, you can pump all the gas in to the system ( with a closed end) , pressurizing it.( voltage expanding the pipe) Current ( flow) will be flowing through the pipe but only at one end. if you stop the pump... the pressure will flow back through the pump. current went in and back out but never made it out the other end...
Also the pressure building up would act like the CEMF…. Counter pressure… ??
like the first switch on cycle acts like a closed pipe til the first 1/2 cycle of the voltage... Then the current tries to start...
oh man... ok
you might want to think about what i'm saying here for a while... its a deep thought that Newman also tries to explain.
Why did Tesla say that 3, 6, and 9 was the key to the universe?
https://www.quora.com/Why-did-Tesla-say-that-3-6-and-9-was-the-key-to-the-universe
Below we see the now familiar square astrology chart that characterized the camp in the desert and the New Jerusalem in Revelation 21. Three gates to the north, three to the east, three to the south, and three to the west. This is generated by dividing the loaves and fishes by diagonals of the squares.
http://dcsymbols.com/design/mark6.htm
Ohm's law holds for circuits containing only resistive elements (no capacitances or inductances) for all forms of driving voltage or current, regardless of whether the driving voltage or current is constant (DC) or TIME-varying such as AC. At any instant of TIME Ohm's law is valid for such circuits.
https://en.wikipedia.org/wiki/Ohm%27s_law
The total Energy of an Object or System is equal to its rest Mass TIMEs C sQuar
X cross
https://en.wikipedia.org/wiki/Christ_(title)#Symbols
some one can check my math...
It travels 300 000 000 m/s or 300 000 km/s
