but the gap between wires and the insulation would make the coils actually quite a bit bigger
Magneton
« Reply #325, on November 18th, 2017, 06:00 AM »
& Xc & Henries.Just thought we could work out the amount of wire, that way by using the maths?
also I have commutator questions: see diagram from Newmans book, pg 292
IMO this is not a "done deal" as there are still items that are not resolved.
My question is still.
Is there 200lb of wire on each coil. Or 1/2 on each coil
I think its 200 lb per coil. So 4 coils is 800lb of wire...
Will need to calulate the Turns
My may question is still.
Hope this relates to what you were asking as the question was a little ambiguous. i.e. done deal?? not resolved??
the questions I had were typed into the drawing (expand the image)
Latest Newman Commutator
148 RPM... 2.46 RPS 62% off 38% on divided into two parts
1 rev in 0.4 seconds
powered for 0.077 seconds, off for 0.126 seconds
on again for 0.077 and then off for 0.126 seconds
but he clearly states in one of his videos that he has made three
improvements to get this level of performance and that he has not disclosed them
clearly the size of his coils and the huge inductance value is dictating the timing
Yes polarity changes.
I'm not for sure but shorting the coil has major binifight of holding the magnetic feild so the rotor turns the rest of the cycle.
Alas don't forget that shorting the coil across the cap gives a little of both worlds. Charge the cap and use it for the next cycle and also slow the magnetic feild collaps down.
