I guess the main thing with my little video is how strong the rotation is...
it almost acts as if it wants to take off on its own...
I was thinking the rotation may be visual evidence of the gyroscopic
effect Newman keeps talking about...
Have no doubt it is...
but imagine that the little magnet was sat upon the coil (in fact you may struggle to get it close to the coil) when magnetic flux is emanating out of the coil...the magnet would indeed take off.
That's what Newman is showing you....A coil with a short/loop (your coil wasn't shorted / looped by the end of each wire from the coil but was by a eddy current running around the wire circumference)
Think of each commutator stage as an entirely different electrical circuit in your head....they are not connected is the best way to picture it.
On Newman's motor, in the segment
'short' stage of the commutator- a electron flow had already been added to the coil prior to the commutator reaching the
'short'segment of the commutator. This induced a magnetic field in the coil.
So think of it like this, the coil is sat there energised in the new part of the circuit called the
'short' (think of it
literally, as looking at your coil there in the vid
-no batteries connected - just
a coil that
is magnetised and has the ends of the wire
shorted/looped).When I say
is magnetised I mean someone could have walked into your room and up to the table there with a compass and if you put a compass near it it would deflect the needle.
The pre stored magnetic field in the coil wants to collapse, in doing so will create what we would normally call BEMF but it's now
in a different circuit so it's
not BEMF but EMF relative to that circuit.
So it does collapse but as it starts doing that, it is creating electron flow in the loop instantly and when you create electron flow you create a magnetic flux.
at the
'short' stage you could think of it more like a permanent magnet but not literally in this example , The magnetic field in the
'short' stage struggles to collapse and dissipate the field, holding the magnet field over a longer time. Our
currents flowing here but it's
not coming from our battery...get it
The current in the commutator
'short' stage is
flowing around the coils closed short/loop
effectively useless and disembodied from the battery circuit.This is where I was stating
we don't want the current in the circuit i.e. the battery circuit....the current is stuck in the coil loop
until all the magnetic stored energy has been dissipated (that is as much as we can dissipate it given time scales) when the switch is thrown again on the commutator segment to
'fire' this is so as to join the looped/shorted coil back to the battery circuit with no residue (very little) current. But the moment it is joined back to the battery the battery current is flowing again. Note.. all our electrons are there back in the whole circuit.
