This really works. Think how much extra funds you will have if your power bill drops to almost nothing. You should poor it all back into your research and keep pushing. There so much happening right now. I beleive we can do it. Its already here. We have to share all knowledge and find the simplest most effective ways to free energy. I think it will be a combination of all the systems we are getting working and I just have a hunch that the final answer will be so easy and right in our face it will make us say we already knew it. and we will
Cold Electricity how to
Alan
Re: Cold Electricity how to
« Reply #101, on February 9th, 2014, 05:53 AM »Last edited on February 9th, 2014, 06:04 AM by Alan
Isn't the effecct just RF power created by the HF oscillations from the cap discharges through the gap? That's why it won't hurt you.
Or is it molecular displacement current and the "rubberbanding effect" described by Stan Meyer, pulling in energy from the environment into the gas?
The resultant ever increasing pulsating opposite electrical voltage fields (603/604a xxx
603/604n) of Figure (8-1) having superimposedthereon counter opposing Rippling VoltageSurfaces (64/B+a xxx 64/B-n) [Dynamic Electrica1 Charging Effect (612) of Figure (8-1B)], now,
set ups, causes, and applies ever increasing (rubberbanding effect) Pulsating Opposite Electrical
Stress (RU-RU' - ST-ST') across Water Gap (Cp) ... encouraging "Particle Oscillation" as a.
"Energy Generator" by way of pulsating "Electrical Stress" as the combustible gas atom particles of
the water molecule undergo "ParticleDeflection" farthest from the point of "State of Equilibrium"
and returning back to "Stable State of Equilibrium" during-pulse off-time (T2) for repeated
"Snapping Action" (Rubberbanding effect) in accordance with bi-polar Voltage Rippling Effect
(1010) of Figure (10-5), as so illustrated in (280) of Figure (3-35).
Alan
« Reply #102, on February 9th, 2014, 06:00 AM »Last edited on February 9th, 2014, 06:07 AM by Alan
And what happens if you put an inductive load on the hairpin circuit, like a 3 phase generator (making the power suitable for normal use). If that works, you can test if it supplies power and if it exceeds input power or not.
You could try to put 2 variable distanced ss plates in the water (at the place where you put the lamp, not in place of the caps) and see if the water turns to bubbles, no one has tried this yet with the hairpin circuit, while this is what Meyer describes, because the molecules are deflected and no real current flows.
Any normal one will not work. The insulation is to thin. Tesla used Shaluk. Also the freq. is important for running different loads and things. Its all experimental but I think its some kind of magnetic standing wave oscillation. I'm only speculating butTesla, Heaviside and Steinmetz said the energy comes from the dielectric realm and they called it dielectricity. You need to start figuring out Asymmetric https://www.youtube.com/watch?v=CjNFzdijWFI&feature=youtu.be
learning curve for me
I lost faith in mechanical overunity, all systems seem to be based on the Bedini motor-generator, but Bedini said that it's function is to create an event ("radiant spikes") in batteries that would charge them for free, nothing more.
I only believe in Stan Meyer and his description on how vacuum energy is siphoned in by elevating the water's or hydrogen's energy state as a mechanical mechanism, without any currentflow.
Tesla used the asymetric system and my friend Warren has already made his and getting results. If you go back trough the posts here I added links to his work and ufopolitics work which can be found at the energetic forum and lots of others replicating and good works. Ufopolitics has a web page and it showd how to rewind all the diffrent types motors. Now im no expert but I look into everything. Always learning as much and as fast as I can. I have a lot of fun but do take all this very seriously. Warren is expert per say in normal school taught EE. He Is getting his masters in EE and he is also learning about t the new physics which is the missing half to what is established. We and many others are learning and observing these effects in our systems. Like plasma spark...cold electricity bendini chargers and so on. We all call the energy we use or are utilizing the Back EMF (electro motive force) what I am finding is the oil whoever...took and begun twisting the info to keep us all on oil. Simply the back emf is the back electro magnetic force and behaved oppisate to our current. I have to go but have lots more to add im out for a min but will be right back to try and help you all understand my openions and facts
Only trough experiment we will figure this out. Electricity is magic...understanding how it works is to know the truth
Alan
« Reply #109, on February 10th, 2014, 09:09 AM »Last edited on February 10th, 2014, 09:13 AM by Alan
BZG:
can you please try the experiment I described with the 2 SS plates on your hairpin circuit at the place of the lamp / parallell to the shorting wire?
If it forms a single bubble, you've hit jackpot
We need an edge Dustin. We need something solid that can be optimized. I think the first step is to unlearn the crap we think we already know and start fresh. Trust me, that's not an easy thing to do, but it must be done. One working example that we can all replicate and show to be OU would do it. Just one. We get that and we can figure out all the rest.
the electrolyzer one shown in video look interesting to measure
here is my 2 cents on epg and water fuel with stan tech I posted this in other thread but wanted to share my thoughts here. It seems to me that no one has achieved the gas outputs that stan said....seems to me that the EPG is the vic because 1. it was the first thing he patent in Canada in 1982 why is because Stan talked and knew of the super powers he was facing so patenting there would be a move i would make if I were him knowing what I know back then. After that he was able to make all patents in USA and other parts of world and slowly the fear of the bad guys faded and dollar signs could have influence him not to fully disclose everything although its hiding in plain sight in the 1982 EPG patent and at the end of Switzerland video he said when you hook this meaning epg to a water fuel cell theirs nothing you cant do. Im building the epg now and I have gotten a pressure cooker a bottle of argon gauges. I have iron electrodes and mixing chamber complete. why we have not seen test done on a complete epg system? I will put all to test. I have all the copper and winding machine ready looking it all over and looks like theres a coating of something on stans unit like insulating spray? any feedback to help me would be great for this. I will post photo of what I have and were I am ASAP and also to address the comment of finding over unity seems we are looking at it wth these catilytic hho LENR reactions if you dont know this fellow he is great and does great work. https://www.youtube.com/watch?v=1T20cuX1py8
update on cold energy tesla from warren
https://www.youtube.com/watch?v=5FetOY29s00
Back to common since schooling
http://www.larryspring.com/overview.html
« Reply #115, on February 14th, 2014, 04:16 PM »Last edited on February 14th, 2014, 08:08 PM by Matt Watts
Appears to be an extension of Ed Leedskalnin's Magnet Current.
What I get from it is that current involves electrons and electrons move much slower than the speed of light, which is somewhere in the middle of what I had heard before.
If only we really knew what electricity is. Even Mr. Tesla struggled with that definition. Seems to me "cold electricity" could be defined as electricity lacking the effect of electron motion--that which only involves these Magnespheres. So if this type of electricity moves through a wire, it doesn't disrupt the electrons within the conductor, no measurable current, but once it reaches a suitable load, it does move the electrons, i.e. the tungsten filament glows. Current appears to come from nowhere.
What I have to wonder is... If cold electricity has no current, than it shouldn't take any wattage to make it. So on the other side, how much current can I expect the load to "create"? What is the best device to use as a load? Where can I get the most bang for the buck?
A lot to think about and ponder Dustin. Keep it coming.
Breakzeitgeist
« Reply #116, on February 15th, 2014, 04:30 AM »Last edited on February 26th, 2014, 12:45 AM by Matt Watts
Awesome work Matt......What is electricity-Everything everywhere- Its the world wind and treadmill of creation. https://www.youtube.com/watch?v=imktKUYIOjw#ws It is mind body and spirit and Stan said it in the beginning of the tech brief...that atoms poses intelligence. Billy is a smart man that speaks from his heart. Hope you enjoy this and I hope I helped you understand electricity and what we truly are. Peace
https://www.youtube.com/watch?v=tdV_Xwh20lM#ws
Thought this was interesting scope shot. .https://www.youtube.com/watch?v=WzcA5-qyZ6c&feature=youtu.be
Yo....Just want all my brothers and sisters to know that i am about to be back just in the middle of upgrading the lab. ill post a vid when its all done got some really cool stuff coming up and i know were getting close just got to try and put some umph to it so we all can triumph!!! Time to get that JUICE! Join Us In Creating Energy.
Peace
Peace
that is really great stuffs.i like that labs. :D
geenee
geenee
Breakzeitgeist
« Reply #121, on February 25th, 2014, 01:55 PM »Last edited on February 26th, 2014, 12:44 AM by Matt Watts
OK so I believe I have something that you all could use....so enjoy
Breakzeitgeist
« Reply #122, on February 26th, 2014, 04:21 AM »Last edited on February 26th, 2014, 04:54 AM by Lynx
« Reply #123, on February 27th, 2014, 10:23 PM »Last edited on February 28th, 2014, 01:14 AM
Gunther Rattay
« Reply #124, on February 27th, 2014, 11:18 PM »Last edited on February 27th, 2014, 11:43 PM
@Breakzeitgeist
did you build and operate the circuit?
I have some questions:
1. pin 8 of NE555 is a power supply pin for the timer and it´s configured floating depending on triangular OpAmp output. can that work properly?
2. the capacitor 47 nF has an annotation without explanation. what does that capacitance depend on?
3. the "Resonance" dial has no feedback loop to the cell or inductance. so you have to get hold on resonance manually?
4. what kind of waveform over the cell can be expected in operation?
question 1 creates some doubts if this circuit will work at all.
