Cold Electricity how to
Breakzeitgeist
Re: Cold Electricity how to
« Reply #150, on March 30th, 2014, 10:19 PM »
Quote from thx1138v2 on March 29th, 2014, 04:54 AM
I found a web site with Tesla's Colorado Springs Notes.
As mentioned above, check out June 26, 1899
As I surmised the hydrogen was to be used for the balloons. Look at the July 5,1899 notes.
"From older notes: Consider generation of hydrogen for balloons in the ordinary way:"
where he looks at electrolyzing and considers the output obtained vs the amp/hours used to be "Ridiculously small!"
Thank you so much for this link it is full of things I have been searching for a long time....Thank YOu
Breakzeitgeist
« Reply #152, on March 30th, 2014, 10:45 PM »
is there a way I can Download all that servers content all the books? is there a way anyone know how to do this?
thx1138v2
« Reply #153, on April 1st, 2014, 06:57 PM »Last edited on April 1st, 2014, 07:23 PM
Quote from Breakzeitgeist on March 30th, 2014, 10:45 PM
Browser Menu->File->Save as...
Of course that means you have to visit each web page. It gets a bit tedious.
There is another document on the internet named "Tesla Said" by John Ratzlaff that purportedly contains every newspaper and magazine article which has statements by Tesla. It is, however, scanned images of the these pages. Some of the pages contain other articles as well and being scanned images they must be read manually since the images aren't searchable text or limited to only what Tesla said. Roughly 300 pages and I think they are in chronological order but his patents are not included.
Speaking of patents, it's important to look at his patents chronologically using the application date rather than the date granted. There can be quite long periods between teh two. Using the application date keeps them in sequence of when he had the idea being patented sufficiently developed to reduce it to a patent.
« Reply #156, on April 6th, 2014, 09:37 AM »Last edited on April 6th, 2014, 09:40 AM
Quote from freethisone on March 23rd, 2014, 02:47 PM
so did u figure  it out yet?
in so many ways cheers Tesla.. he used the gaps as resisters, very low..
ok
its a hair pin.
dealing with this formula, the conditions are related.
take what you can learn from this.  home made semi conductors show a negative reistor. http://www.sparkbangbuzz.com/els/zincosc-el.htm
http://www.freegrab.net/Update%C2%A0Tesla.htm
click http://www.bibliotecapleyades.net/tesla/coloradonotes/coloradonotes03.htm#Colorado Springs Notes - July 1-31, 1899
Breakzeitgeist
« Reply #159, on April 10th, 2014, 08:35 AM »
ok Plasma Electrolysis got to excited to fast but Fusion coming up. its even cooler than the sun
« Reply #160, on April 10th, 2014, 12:21 PM »
Quote from Breakzeitgeist on April 10th, 2014, 08:35 AM
Approximately how much juice are you pouring into that electrode?
Breakzeitgeist
« Reply #161, on April 10th, 2014, 04:53 PM »
less than an amp at 120 V I will have all the meters set up and temp sensor but that was just plasma electrolysis.  The plasma electrolysis provides the perfect environment (if prepared correctly) to start and sustain a nuclear fusion reaction, resulting in the fusing of hydrogen ions to form helium isotopes. which is even cooler to see but working out the bugs and will be explaining all of it soon like the cold electricity so you all can check it out....i am almost their, so soon, but have some more vid of the plasma electrolysis about to post awesome to look at...Peace
Breakzeitgeist
« Reply #165, on April 10th, 2014, 08:44 PM »
so from about 7 min in until the end of vid notice its almost bout to fuse that is what it looks like right before the pretty stuff happens so that's coming just working it out i will fully explain when I get this done.
« Reply #166, on April 10th, 2014, 08:52 PM »
Dustin, I saw an experiment similar to this and when the voltage gets near 300 volts, that's when things really get cook'n.
« Reply #167, on April 14th, 2014, 07:38 AM »Last edited on April 14th, 2014, 07:43 AM
matt you posted this a wile back  arc
https://www.youtube.com/watch?v=lNSAXbZfnbE#ws
it all goes full circle, plasma arc stark k , tesla turbine, faraday disck gen. i had thought many here are building these devices. i dont see much along the lines of advance yet.  who is willing to do some experiments to show proof. or who will even build a pipe magnet like Edlee with a inner and outer tube. this can be helpful in geet reactors too or any system plasma is  contained in a magnetic field.
Im not sure if you are ready, but i am..
« Reply #169, on April 14th, 2014, 08:26 AM »
they say it cant be done, but if we include a high voltage bias, ac to the reactor chamber it could make a huge impact.
dc cold fussion with ac biased medium.
« Reply #172, on April 16th, 2014, 05:56 PM »
Quote from Breakzeitgeist on April 16th, 2014, 04:57 PM
This is a fusion reaction and what I am trying to achive, this kid DaVID MAKES IT LOOK EASY
You get up above 300 volts and  you'll be able to do it too.
Amsy
« Reply #173, on April 17th, 2014, 01:22 AM »Last edited on April 17th, 2014, 05:43 AM
I´m investigating the "Cold Fusion" (new name LENR) since Naudin replicated it few years ago. http://jlnlabs.online.fr/cfr/index.htm
It is a very interesting topic. Because here the routes of Teslas Spark gap, Meyer and co are meet together.
One of the most important notice of the plasma/cold fusion is, that when the right spot is hitted (voltage, maybe called "resonance" :roll:), the input current is going down and the plasma can give us additional energy: http://jlnlabs.online.fr/cfr/ape/apenrg.htm
So the device can give us: steam, hydrogen and alternating current. With the gained electricity we can load car batteries or drive other hydrogen cells.
When I saw the pix of meyer´s 11cell WFC, my idea was, to connect such plasma cells together. So the generated AC in each cell can be catched with a fast switching diode to get out DC. Dave Lawton did the same thing.e. (Attachment)
Of course to get the right voltage, we need some step up from 12 to 100-300V (??). A VIC or a similar device would possible be a good solution, because the additional coils can block the high frequent AC which is generated in the plasma. It is like a line filter for electric tools or something.
The collected AC out of the plasma can light bulbs (lawton) or we can load a car battery or something like that. The steam out of the cell can be cracked to hydrogen with a similar device like the gas gun.
Some years ago I do a test like naudin with a tube cell, at a certain point, the voltage drop on the tube cell switched from 300VDC to a small negative value, the cell was generating power instead of consuming. To hit this spot, the temperature of the cell must be high enough. The input current will go down at this spot.
I can recommend to try such a buildup like naudin. It does work! :)
Quote from naudin: The APE device works like a non-linear relaxation oscillator (or a negative resistance oscillator) driven
by the plasma discharge process used in the negative conductance region.
So Naudin descripted it as a negative resistance. Here is a page which explain what happens when a negative resisatance is built in a resonant circuit: http://www.st-andrews.ac.uk/~www_pa/Scots_Guide/RadCom/part5/page1.html
Quote: A negative resistance value means that alpha is positive. This means the oscillation amplitude and energy grow exponentially with time.
Did meyer use the water as a negative resistance like naudin and tuned into this resonant circuit? How we can instantly make water to a negative resistor without heating it up or make a plasma first? Is it enough to drive the WFC with a short 300VDC pulse to initialize the water to a negative resistance so the resonant circuit can work like desripted above?
