Hi This Circuit Seams to be Amazing and Works just fine,
I am not builder of it I am just a Messenger
if you tell me how to upload a picture i will, thanks.
so did u figure it out yet?
in so many ways cheers Tesla.. he used the gaps as resisters, very low..
ok
its a hair pin.
matt the point is if you are afraid of it, i ask if you understand it..
In the Faraday unipolar generator "the current," as Tesla noted, "set up will therefore not wholly pass through the external circuit ... and ... by far the greater portion of the current generated will not appear externally..."(7) By having the magnet completely cover the disk, Tesla made use of the whole disk surface in current generation instead of only a small section directly adjacent to the bar magnet, as happened in the Faraday device. This not only increases the amount of current generated, but, by making the current travel from the center to the outside edge, makes all of that current accessible to the external circuit.
More importantly, these modifications on the Faraday design eliminated one of the biggest problems in any physical system - the reaction to every action. It is this reaction that works to cancel out whatever effort goes into causing the original action. In an electrical system if there are two turns of wire wound next to each other and a current is sent through the wire, the current passing through the first loop will set up a magnetic field that will work against the current passing through the second loop.
The spiral divisions in the disk cause the current to travel the full radius of the disk or, as in his alternative version of the generator, to make a full trip around the outside edge of the disk. Because the current is flowing in a large circle at the rim of the disk, the magnetic field created by the current not only does not work against the field magnet above the circular plate, as in conventional generators, but it actually reinforces the magnet. So as the disk cuts the magnetic lines to produce a current, the current coming off of the disk strengthens the magnet, allowing it to produce even more current.
check out circuit in video.....TRY IT
I see, so in Tesla's drawings those are just normal capacitors, not WFCs of any kind. And Tesla never actually dabbled in any kind of electrolysis then, someone has simply swapped out Tesla's real capacitors for two conducting plates submerged in water! :s
No. Tesla dabbled in WFC's too and those are cells.
Then I've certainly not seen that patent... anyone got a link to it?
